I am sure that this is a topic that has been discussed many times before but here goes. I am planning to fit a single Mikuni carb to my 850 engine which is currently being rebuilt by Norman White. There does seem to be 2 schools of thought on which size carb to fit; the VM34 or VM36. Has anyone got experience of using both or either and which is the better? I am looking for easy starting, good tick over and low to mid range pick up without hesitation. I am not looking for out and out top end performance as I am far to old for that :-)
Not used either of these, but..
Single Mikuni
I fitted a 34mm single Mikuni to my Mk3 around 20 years ago. I have done around 80,000 miles with the carb needing little attention. I was advised at the time that a 36mm carb would increase the petrol consumption but would make little or no difference to the useable power other than at the top end in 4th gear.
Jap Carb
Hi Tim,
Was that attention late August 2017 on Olivers Mount, Scarborough and fixed by the Great Late Mark McLennon? I seem to remember the carb coming loose and you had to manually richen the mixture to keep going. I have the photo. Treasured memories.
For me, my Mk 3 Commando runs very well on a single 32mm Mk 1 Amal. (68 mpg) E0 petrol.
I run a VM 34 with the 2-1…
I run a VM 34 with the 2-1 manifold cleaned up to blend with the ports and the largest K&N filter that would fit in. Running with a PW 3 cam, good for road speeds but probably looses out at top speed on a track. Pulls strongly low and mid range and uphill.
Hi Graham,
Smaller carburettors are a lot easier to calibrate for good idle and smooth progression from idle as the gas speed is greater. Personally, I would expect there to be an undetectable power difference (caveat - both carbs being properly jetted) between the two carbs until the engine was north of 5000rpm.
When the Ducati 900 was a current model (late '70's) I got to ride both a 900SS and a Darmah on the same day.
The Darmah was by a long way the nicest of the 2 to ride - not talking ergonomics or comfort - as it 'drove' so much more easily at normal speeds and especially around town. The Darmah had 32mm carbs, the SS 40mm.
Hope this helps your decision,
George
