Following a pretty serious racing accident I lost most of my (Somewhat limited.) facilities, including my lathe.
Also it appears that over the years most of my contacts have retired or worse..
Therefore I'm looking for somewhere/someone who would take on relatively simple work.
SE England preferred.
TIA Paul.
These guys do a full range…
N. Wales :( But PM me with…
N. Wales :(
But PM me with what you have in mind and I can probably sort you out.
GWR Fasteners also have a…
GWR Fasteners also have a decent range of spacers and studs
https://www.gwr-fasteners.co.uk/engineering-studs-675-c.asp
Thanks so far guys!
Cheers for the links John and Steve, maybe I can use them for studs n things.
PM you Stan.
Still looking for someone/company in the SE if poss'.
Why not come along to your…
Why not come along to your local NOC group and see if you can make some personal contacts? There are also Facebook groups which appear to contain fanatical lovers of lathes...but who never seem to make clear what they actually make.
I'll probably do that David…
I'll probably do that David.
Been down the Sussex branch, but wasn't at this stage then and real-life's caufgt up with me a bit, as much as I try to ignore it.
Hoping that some might like…
Hoping that some might like to earn some beer money Ian.
These guys do a full range of stainless studs with imperial threads including different thread forms on each end.
https://www.motalia.co.uk/studs.html
I have used next size up nuts as spacers and stacks of washers (good for working out size of spacers too)
