Commando 750s issues
Hi all
I have a 1969 750s back to Uk on NOVA. Have rewired and replaced ignition with Boyer Bransden, new coils Ignition switch, leads, caps plugs, everything new. It came with a Mikuni single carb conversion and proved very hard to start. Established it is sparking fine and timing seems ok does not spit or kick back when kicking over.
When it did eventually go it ran for 30 seconds and faded away. Tried switching to a newish pair of Wassell carbs that I knew worked on my N15, (fitted with 1972 commando engine) slightly easier to start (with a bit of tickling), but still faded away. Replaced Wassells with original Amals from the N15 that I went right through with new jets, gaskets, etc. Again an improvement, initially it ran for about 5 minutes (this was with another new pair of NGK's) then restarted,  which it had previously refused to do, and I was able to choose to actually turn the ignition off before it faded away, both times.
Thought I had cracked it, but an hour later back to how it was before. It doesn't seem to flood even when tickling and giving it 20-30 boots to try and start it. It soots the plugs very quickly and seemed to me to get hot quite quickly on the one time it seemed to go properly. Oil going round ok, seems to charge ok, looking at ammeter, and it does sound very nice when it does run.
Seems to me something to do with carbs but symptoms persist with three different carb setups so I am losing the will to live. I wonder if this problem sounds familiar to any of you out there, I would appreciate some help if so.
Thanks very much
Nottingham area
If your carbs are not flooding then check the fuel taps and the breather in the tank cap. Once you have the carbs flooding correctly with fresh fuel and plugs and it still won't start then :
90% of carb problems are electrical.
After 3 changes of carb I would be doing the full debug on the Boyer.
http://vintagebikemagazine.com/technical-articles/boyer-trouble-shooting/
Also check the earth path from the engine back to the battery, those double sparks need a path, a temporary wire from head to battery earth is a quick test. Also watch for distance from the boyer magnets on the rotor to the stator pickups, too large and the box does not get triggered.
Dear Mike
I would check fuel flow from tank, not unknown for filters to block or taps themselves to fur up, you dont by any chance have original fibreglass tank with sealer in it do you.
Check flow by removing pipe from tap and catching half a pint in a glass jar, then as well as flow you see what colour it is. If flow starts ok and slows, open tank cap and see if that improves it, breather holes in caps are known to block too.
Can't help with ignition as I am dinosaur points man!
Regards Martin
Nb When flooding carbs you should get a steady flow if you hold plunger down, if not you have bango filter and valve in float bowl to check too.
Hi Martin
Thanks very much for swift response. It's a metal tank but judging by weight it has sealer inside though not visible through cap. Will check out fuel flow as suggested and look at fuel quality could be old sealer contaminating fuel perhaps??
Hi William
Appreciate quick reply, will check over the weekend, thanks very much
Hi there all
Thanks once again for your help.
Have checked the fuel flow from the tank which was fine, petrol clear and clean, with cap open and closed, tried a different tank anyway, set an earth wire between main frame earth and engine, (checked continuity was good with a meter) and still no difference. Rechecked ignition timing rechecked coil wiring, tried different coils leads and caps. still won't run.
Will swap over Boyer system and rob poor old N15 again as I know that one works ok. If that doesn't work does anyone know of a good Commando specialist in East Midlands area who I could take it to, as I am ready to admit defeat?
If your carbs are still not flooding then the float is not being depressed by the tickler, I lengthen it by screwing in a self tapping screw into the rolled shaft inside the float chamber, it then becomes easily adjustable.
Hi John
Thanks for your latest post. Sorry I did not put that very well, the carbs are flooding as I would expect (and remember from the late 70's when I had a couple of Interstates) when tickled, but I meant to say that the combustion chamber does not seem to be flooding even when kicking over to try and start it unsuccessfully 20 or 30 times. I was expecting the plugs to be soaked in fuel when they came out, but they were just barely damp.
Hi John
That was my first thought too, or some form of fuel starvation, so stripped and cleaned the original Mikuni adding new jets seals gaskets etc. Then tried a brand new Mikuni pattern carb. Then fitted a pair of Wassells that I knew were ok, then in desperation stripped and cleaned a pair of Amals with jets seals gaskets, everything new, quadruple checked long dog leg passages were running clear between airscrews and chambers, as I know they are the biggest cause of blocked pilot circuits on Amals. 4 different carb setups and the fault remains constant. It is doing my head in!
The Amal 25 pilot jet/bush can only be properly cleaned with a #78 or 16 thou drill, no amount of cleaning with fluids will resize them properly.
As you have tried different carbs and seemingly have a good spark, how confident are you that the motor is correctly assembled or in good condition? Cam timing correct? Sticking valves? As it is new to you, there is no history of what fuels or oils it has run on which could cause the latter. They don't have to stay open much or for long to lose compression when starting.
Another thought, have you tried a/ using the plugs from your N15, or b/ tried starting the N15 with the Commando plugs to check that they work ok? Wouldn't be the first case of no spark under compression reported on here.
Good luck,
George.
A good thought re: blocked exhaust. For a quick check, rather than taking the silencer off, a pair of rubber gloves stretched over the silencer ends will let you know if it is blocked or not.  If they inflate or get blown off, it means no blockage.
Mike, On a similar line, is the air filter clear? Maybe worth trying with it removed.
Regards, George
Thanks for latest posts, appreciate your thoughts. Will work through all those suggestions.
Best  regards
Hi Mike.
You say you changed to Boyer ignition but not whether you did this anyway, or because it wouldn't run properly from the off.  Here are three additional thoughts considering your change of ignition set up anyway.... and considering that issues have a tendency to be related to the last thing that was touched!
1.The degree dial (I forget the correct terminology for this) fitted to the outer primary case that you are using to strobe your new Boyer system to, can often be completely inaccurate.  Mine was 6 degrees out!  Maybe the previous owner knew this and had made allowances for it but you have not. A check with a degree wheel at tdc and 28 degrees before tdc will reveal this. Also make sure the chain case cover always end up in the same position when it's removed and replaced.
2. Make sure you didn't buy plug caps with built in resistance AND plugs with built in resistance. Only one OR the other is needed with electronic ignition, both causes problems.
 3. Dont forget it is negative earth. Double check the coils have the correct positives and negatives. Coils will work if it is wrong but they tend to produce a weaker spark and fade. Probably you are sure of this if you have run an external earth wire but its worth double checking as you dont know what has been done to the bike in the past.
Regards Graham
As well as the degree disk being out, I had a rotor that was out by many degrees for some time, started ok and drove ok but top end a bit flat. I re-timed it by guess and top end acceleration eventually. Lot better acceleration from 70+ on the motorway! Then Police man stopped me! 'do you know your rear light is out?' phew.
Hi there Gents (and Ladies**), and thanks to Graham and Alan for latest posts.
Thought I had better check the cam timing first and in the process noticed that the bike had wet sumped almost all of the oil out of the tank in the space of 7 days. Having checked the alignment of the dots on crank and intermediate pinions and 10 links between the timing marks on camshaft and intermediate, thought that cam timing was ok.
Removed the oil pump and primed it with oil but could not seem to get much suction out of it. Don't know if this is because you can't generate enough speed to replicate the oil pump action or because the pump is duff. Was wondering if the oil pump was not returning from the sump effectively and the bike is wet sumping itself when it starts running, hence the petering out? The oil did seem to be returning to the tank (although not vigorously) and there appears to be decent feed to the top end. Checked oilways flowing freely. This leads me to think it could be the oil pump. I hope it is because I just spent £250 at Andover Norton for a new one!
I bought the bike as a non running import from the USA. I junked all the wiring as it had already been butchered and was 50 years old. Wiring is fairly basic as per attached wiring diagram, Boyer wired in as per their diagram. No blown fuses to report and earthed to frame/headlight/engine at several points
One thing I did find a bit odd was that the ammeter flicks to the discharge side when ignition switched on as you would expect, but after a couple of seconds goes back to zero. The only other bike I ever had with an ammeter was an AJS 16MS and that stayed over in the minus side until it got going (or the 6v battery went flat) but that had a magneto setup. Is this normal behaviour, just the coils taking a charge, ready to discharge the initial sparks, or have Mr and Mrs Cockup galloped into town on the wiring front?
I have only been able to set up the timing statically so far, the motor has not kept going long enough to set the strobe up yet for fine tuning but I take the point about the accuracy of the timing marks.  Don't know if NGK BP7ES plugs (tried 2 new pairs) have built in resistance or not, but by chance, of the 2 new caps I have tried, one pair had resistance and the other did not, and there was no difference. The poor old N15 is sitting in the corner with no carbs on at present so cannot try a swap over just yet.
I have not fitted the new air cleaner box and filter yet, the previous owner was running a single Mikuni with no filter and had binned the standard aircleaner.
Also checked valve operation and seems fine, the inlet valves have a nice bright ring on the seen though the plughole which suggests to me that they are seating properly. Good compression and induction seems to be ok when the sump is not full of oil.
I am looking forward to try starting the bike without any silencers on and I bet the neighbours are too. Watch this space for more excitement and for an advert for a nearly new oil pump if that does not sort it.
(** got to keep it diverse and inclusive)
If the NGK has an R in the number it has a resistor (or not as the case may be).                              As regards Ammeter behaviour, the Commando is alternator while the AJS was Dynamo, although battery charging is similar as the two systems are different the results on the meter can be different. So in this case the Ammeter results are not anything to worry about. If the lights work well then the battery has enough to get the machine going. Charging the battery is almost incidental.
Sorry Mike. I just noticed I wrote negative earth. Of corse I meant to write "Don't forget its positive earth"  Nobody picked up on it so I suppose my mistake was obvious.
I've still got my money on the wrong ignition timing being the issue. You said the engine seemed to get really hot very quickly. This is a classic sign of the ignition being too far advanced. Hard starting can be either too advanced or too retarded. If you have the timing case off you can make yourself a degree dial with a print out of a downloaded online dial stuck on an old CD and check it in half an hour. If the bike is back together I would put the original carbs back on with the original settings and try moving the Boyer backplate clockwise a good few degrees and see what happens. If its not better try moving it anti clockwise. My most successful attempts at ignition timing were usually achieved by trial and error and not with a strobe light.  It can't do any harm to try (look out for kick backs though ☺)
Oil pumps can be successfully refurbished by the way. Several companies offer this service. I had mine done by RGM. It will always leak by a bit though even when it's perfect. You just have to ride it regularly!
