I have recently acquired a 1973 Commando Interstate 850 and as part of the restoration want to rebuild the wheels with alloy rims and stainless spoke onto which I wish to fit modern tyres. There appears to be so much contradictory advice on wheel size, rim width and tyre size that I am somewhat confused. I like the modern design of the Avon Roadrider or Metzler Roadtec 01 but have no experience of either of them as my last Commando was a 1968 fastback and that was 40 years ago when there as very little tyre choice. I would be very grateful for any advice and recommendations before I shell out over £600 on this upgrade. The rest of the bike is pretty stock so far although i will be putting on new rear shocks whilst it is in my workshop.
It's largely a matter of…
Coincidence
Thanks Stan,
Thanks for the advice.
Interestingly my other bike is a 1979 BMW R80/7 in period cafe racer trim that I have almost finished rebuilding and those are the exact wheel and tyre sizes that is has, running on Bridgestone Battlax tyres. I haven't ridden it yet so don't know how these tyres perform compared with say the Avon Roadrider
Radials
Good to see someone thinking out of the box Graham. If you want modern rubber and prepared to fit the recommended rims, Conti Classic Attack radials are available in 100/90 R19 and 120/90 R18.
They use tubes and 2.50" rims both ends rather than the 2.15" front. Equivalent Bridgestones or Metzlers should also work well if your sizes are available
Conti don,t seem to do a 100/90 R18 front radial to give the probably optimum 18" set Stan mentions for his race bike. I used a similar TT100 setup on my Atlas special but with 3.0" rear rim and this was the best of my crossply fitments. Instant improvement. However the 19 front and 18 rear on 2.5" rims would be ideal in your case.
The grip and mileage of radials on correct rims should far exceed the usual Roadrider/TT100 cross plies and they give a smoother ride. Contrary to popular undying folklore I have found radials work well provided the correct rims are used.
Thanks for the information…
Thanks for the information Neil. I take it that with the combinations that you suggest with 2.5 inch rims front and back and the Conti tyres there are no clearance issues front or rear.
I don't suppose you know where I can get a hump back saddle do you? I have the Interstate and whilst I love the Corbin saddle they don't make one for the Interstate which is ironic since it was the US market that it was designed for. All the usual places for saddles are showing the hump backs out of stock.
Tyre sizes
You can check your clearance with the tyre widths below or compare to your BMW. Most modern tyre dimensions are the same so your chosen Metzler or Bridgestones should be similar. Odd man out is Avon whose rear radial tyres are usually wider.
The 5000 mile life many Roadrider users report is unacceptable in my view for a lowish powered middleweight bike usually ridden in cruising mode (and there,s nothing wrong with that)
An Access Norton forum member used Roadriders with 2.50" rims front and rear, maybe 19" and raved on and on about them. Unfortunately his loud, confrontational and self opinionated manner alienated too many to take much notice.... Bad bloke to get stuck with in a pub
Conti Classic Attacks
100/90 R19 2.50" rim 101mm wide x 663mm o.d
120/90 R18 2.50"- 2.75" rim 119mm wide x 673mm o.d
Radials are the way ahead as…
Radials are the way ahead as Neil points out, but the classic attack is a track and road approved tyre unlike many other radials the most of which are road only. The life of these particular road and track approved radials is not great, as many super bike owners have found. You don't get something for nothing.
Realistically, the classic attack though very good, are expensive compared to Roadrider Mk2, which is more than adequate for the majority of Norton riders.
Thanks Neil i will do some…
Thanks Neil
i will do some measuring up this week before I send the wheels off to be rebuilt. I must say I like the look of the radial tyres ans tyre wear isn’t really a big issue as I do a fairly limited mileage .
It's largely a matter of personal taste. I run 100/90 18 front and 120/90 18 rear on 2.50 akront flange-less rims - on a race bike and it works for me.
On a road bike, I think I'd stay with a 19" front and, to future proof it, choose BMW /7 series sizes, i.e. 3.25x19 front on 2.15 rim and 4.00x18 rear on 2.75 (or 2.50) - there's a good chance that these sizes will be available a long time. They do look "right" on a Commando with the std front mudguard and handling is solid.
Going lower profile on the tyres will reduce ground clearance which might be a problem with std exhaust. Going too wide at the front can cause wobbles and heavy steering. You might just get away with a 130 in the rear but no wider.
