Hi.
Despite having owned over 25 motorcycles over the last 40 years ( mainly Laverda), I've never had a British Bike before. I decided I should put this right, and as I always liked the look of the Commando's I've recently purchased a Mk2A fastback from the NOC classifieds. Picture attached.
It's been recently rebuilt by someone who seems to know what he was doing, it starts and runs well and pulls like a train. However,......( there is always a " however" !)
...I am not impressed with the handling. It's great at low speeds round country lanes, but as soon as it's on the open road, above approx 65 mph it has a tendency to weave like a demented chicken being chased by a fox. The first time it nearly had me off the bike.
After much reading of the forums, t'internet, and talking to the more knowledgeable, I have tightened the vernier iso-elastic blocks up hard ( I understand the police used to do this ?) I have just about new Avon RoadRider tyres, and have increased the pressures to 30/32. This has slightly improved matters and I can normally get to about 72 before the weaving starts...but I still do not feel it's correct, and am very unhappy with the handling.
The forks and shocks appear ok, with decent rebound damping, and the wheel alignment seems ok to the best of my knowledge. Rear shock is set to least spring preload ( would increasing this help - I'm 15stone?)
The head bearings etc are as they should be.
Questions..is this the best I can expect from a Commando 850 ?
I know it won't hurt, but is wheel balancing something I should look to as a root cause?
Any other suggestion as to most likely areas to work on would be gratefully received.
Many thanks,
David
David, No, the bike should…
Rear shocks
Put them on the hardest setting but also make sure they actually work. If the damping has gone, the handling will go with it.
My 850 Mk3 Commando would shake its head decelerating through 30 mph but was great at speed.
Do you have the same section tyres front and back? They can prefer a narrower section on the front.
...Glad to hear it !
"No, the bike should be good until it tops out."
Thank you for your reply. That's exactly my thought!.
I don't expect it to handle like my Laverda, but this cannot be right.
Yes tyres appear mounted correctly, with the radial moulding on the sidewall parallel with the rims. ...rims run true on correct spacers, verniers are correctly mounted..the way you described, and are currently locked up tight. It's weird, because overall the bike is in very good condition, not concourse, but A1. I've been over the frame, but the way it weaves suggests something dynamic, not just something bent. I'm going to take each shock off and examine it very careful are replace all mounting rubbers. I'll get the wheels dynamically balanced, and keep going till I find the problem !
Shocks are next point of investigation.
Thank you for your reply. Tyres are good. 90/90 front 100/90 rear RoadRiders. Currently 30/32 psi.
Head shaking I can cope with no problem ( my SF2 does that a fair bit on the poor roads around here), but this it a real weave. I'm thinking more and more, " undamped oscillation" so going to whip the shocks off today to investigate.
Are the head bearings too…
Are the head bearings too tight? You do say "they are as they should be" - but what should they be? They were (usually?) fitted with pairs of ball bearings, but some think they can "improve" them by using tapered rollers. My Dommie felt unsafe at speed when the taper rollers were too tight.
Thank you for your reply…
Thank you for your reply. The head bearings are perfect...first thing I checked. Recently renewed by previous owner and with exactly the right amount of free rotation. . Also stations are good. If I can get a free half hour this evening, I'm going to check the rear shocks.
Check the headsteady, the 3…
Check the headsteady, the 3 allens clamping it to the head, the bolts for the sideplates and condition of the rubber buffers. Check the play in the swingarm, both the spindle fit in the bushes and the spindle fit in the cradle. Consider Kegler clamps for the cradle to stop the swingarm spindle wallowing out the hole in the cradle.
https://www.accessnorton.com/NortonCommando/heinz-kegler-clamps.15974/
Thanks for all the help…
Thanks for all the help. Will double check all these points.
A more general question. In the real world, does anyone think dynamic wheel balancing helps? I've never balanced the wheels on any of my other bikes, and never had a problem.
Thank you.
Weaving around
No David, my dear old Mk2A 750 is as steady as a rock up to about 75, (when my courage runs out).
When I bought the bike 25 years ago the handling was abysmal, certainly compared to my beautiful 99. Over a period of time everything was cured, which included the three following mods: Norvil headsteady, (huge difference), Mick Hemmings verniers, set at 3mm gap, to replace the worn out shims, new s/arm spindle and bushes, with two securing nuts.
I am a bit surprised you got throught the MOT, when they were required, as a good tester who knows his stuff can usually identify something that is not quite right. In my case one test years ago my local chap pointed out that the big gearbox adjusting nut was loose, which it was, but I had not noticed, which explained why it had started to weave a bit on bends.
Owning a Mk2A is a challenge, I can tell you, but it is great when it is going well.
Andy Bone
The hinge in the middle...
A number of Commando faults feel more 'dynamic' than on more rigid machines. Everything does have to be right for the isolastic system to work and not amplify faults.
I'd echo the need to look closely at the head steady. Wheel a Commando around with fuel tank and steady off and you'll see just how crucial this triangulation is. The engine (and rear wheel) are able to move dramatically out of line with the headstock, just by turning the bars at walking pace and allowing the weight of the machine to transfer.
My preference is for the rose joint type of steady, but the standard type shouldn't be causing the problems that you describe.
Have the wheels of the bike been rebuilt ? In my experience, one of the most common faults is caused by rim offset. The Commando disc front wheel was problematical to align at the factory and very few wheel builders manage to get the disc side spokes to stand almost vertically, as they should.
It's surprisingly difficult to see this if using different width rims and / or tyres. Have you measured the offset of the rim from the fork leg on each side ? If the front wheel is offset but 'in line', the steering will be continually trying to correct itself.
Wheel offset is correct. I…
Wheel offset is correct. I will look at the head steady, and possibly fit a rose joint unit. I would rather have poor vibration control and good handling than the other way around.
Just trying to work out how to get the rear shocks apart, since they are of the shrouded type and therefore won't take my spring compressor.
Wheel balancing
I would definitely get the wheels balanced. I recently had Avon road runners fitted to my commando and was quite surprised at the amount of weight needed to balance the rear tyre. Handling does seem more stable at speed after this. I am told that front wheel balancing is less important. My other advice is change one thing at a time and test the result. Otherwise you end up going in circles - figuratively speaking!
Nice looking bike by the way.
Wheel balance
Steve, I believe you have it the wrong way round. Any bike I have ridden without balancing the front wheel has been like riding a pneumatic drill when up to speed.
Commando's may be sensitive to rear balance, especially if the 'security' bolt assembly is still fitted, as that adds a LOT of weight that would need to be balanced out, but at normal road speeds rear wheel balance is not normally an issue unless, as said above, it is massively out.
For the original poster, I read an article a couple of years ago,- I'm sure it was in the Roadholder, - about 'the worlds straightest commando', or something like that, where the writer went into a deep dive in getting his bike to handle as it was supposed to. Suggest it is worth a search for it.
Regards, George.
Static balance should be…
Static balance should be fine. Dynamic balance is for wider wheels.
I don't think...
... you need any modifications to the original setup but the crucial areas to look at in my experience are isolastic clearance (done properly with the weight of the bike off them), steering head bearings and swinging arm bushes. My second Commando which I had for 20 years and 50,000 miles or so never gave me a moment's concern regarding handling.
You don't need to do the isolastics "up tight" but you do need .005" as near as possible clearance.
New head bearings, running…
New head bearings, running smooth as, with no excessive movement. Same for swingarm bearings. Front forks also overhauled. Iso-elastic verniers up tight at the moment, for diagnostic purposes. Might be rear shocks, but can't get the springs off because of the shrouds. Then I'm going for wheel balance, and a rose joint head steady.
Something of a "bitsa" you…
Something of a "bitsa" you have there...
Anyway, please don't lock up your isolastics, you will break something. Adjust them as per the manual.
Commandos are strange bikes that are very, very easy to turn into evil-handling nightmares. And at the same time they can tolerate 'looseness' is all the things you read about needing to be this way or that. Often you will change just one thing, e.g. a front tyre, and it will go from one extreme to the other. best advice is to find someone local to you who has a Commando or two in their shed and will take a look at it for you - whereabouts are you?
What I will echo from others' comments is that no, the bad handling you are experiencing is far from the best you can expect. And without any special bits a standard Commando will easily out-handle a Jota.
Wheel Alignment
David,
You said that wheel alignment is correct to the best of your knowledge - how did you check it? It is quite easy with some methods, e.g. string, to get a misleading result.
Andy
Killer weave sorted.
The dangerous element of the handling has been eliminated. It was as simple as increasing the preload on the rear shock absorbers !
I'm happy to ride the bike at over 90 mph now without the impression that the bike is trying to kill me.
I'm sure that the handling can be refined significantly however, so will go through everyone's suggestions in turn.
Thanks so much for everyone's input and advise, it's all been greatly appreciated.
"The World's Straightest Commando"
George, I think this is the article you mentioned, I found it somewhere on't interweb about 4 years ago, but the original dates back to 1998.
That's us..
.. told then.....
Who needs a featherbed anyway. My plunger garden gate ES2 handles like a dream......
It would be worth checking…
It would be worth checking the right length shocks are fitted, they should be 12.9" centre of eye to centre of eye fully extended. I run with lowest preload solo and have no weaving issues, could be 12.5" are fitted and hence the extra preload needed. Adding preload does not change the spring rate just raises the rear of the bike.
Wheel balance and tyre pressure
David, it is well worth getting the front wheel balanced, I gave up fitting my own tyres years ago, apart from trials etc, as at high speed it really matters.
Also try adjusting tyre pressures to suit your weight and riding position. Sitting on a Roadster is very different from an Interstate coz your weight is in a different place and as you found out shock pre load affects it too.
I have recently fitted a pair of Falcon shocks and the improvement over say Hagons has been remarkable.
As yet no-one has mentioned…
As yet no-one has mentioned oil in the Roadholder forks. If one side has less oil than the other, they are underfilled or overfilled or the wrong weight of oil is used, weaving is a likely outcome. I suggest sae 20. While you are at it Kev Feltoe's modification described in Roadholder recently will facilitate future fork oil changes.
Front Tyre
Just wondering if you would be better off with a 100/90 on the front of an 850.
David,
Are the tyres fitted correctly, ie radially and square on the rims
Are the iso's fitted the right way around, if they are vernier they need to be front = adjuster on right, rear = adjuster on left
Are the wheels fitted correctly with the correct spacers.
Check some more, you will find out why.
