Does anyone know engine number or date when the cover over the rear timing case was replaced with a solid casting. (I am referring to the cover over the early points position).
Steve
Well it probably happened…
Well it probably happened before 206XXX as my cases in that range are solid.
Yes, I was asking because my…
Yes, I was asking because my case is solid and engine number is 2059xx and wondered if inner case may not be original.
The Atlantic Green Norton…
The Atlantic Green Norton page is down but that shows that change and others made during 72 production such as removal of a stress riser at the rear of the cases. There will be a 3 digit number stamped on the bottom of both case halves, if they match then the cases were machined as one set. Mine are matching so the 206XXX is valid for both halves.
Roy Bacon's books are written from Press Releases and so mid year changes already made are announced at model year changes to increase the perceived improvements of the model year change. Dave Comeau's Atlantic Green site information is based on actual engines.
In his book, Norton Twin Restoration, under Crankcase Types
"The whole assembly was altered for 1972 when the breather went to the base of the cases and internal webs were added.At the same time the threads changed to the Unified form. For the 750, in 1973, the distributor-drive hole was filled in, the blanking plate and fixing holes being deleted."
Unfortunately, he does not quote the relevant engine#.
