cylinder head studs
could anyone tell me if the two 3/8th studs at the front of the head are cycle thread or BSF as mine have stripped in the head and i need to order a helicoil kit.
They will be a coarser thread in alloy.   possibly whitworth or UNC.   Check on RGMs site.
BSF normally works in alloy, BSA used it as well but the Norton head just gets too hot and the alloy becomes brittle.
Thanks for that info guys much appreciated i will get on and order some now.
Was not a problem on Dommies with whitworth threads, I suspect its more to do with the shockingly poor  alloy  casting quality  that  I found on heads from Plumstead . Had to file off casting flash and bead blast to close open pores and  get a passable finish.
