Oil supply valve
I’m looking for an oil supply line ball valve for my Seeley Commando to stop wet sumping - only decent ones I can find all have reduced bore (e.g. 6mm). Is it ok to use a reduced bore or any advice on where to obtain nicely engineered full bore valve (3/8” or 8-9mm).Thanks, Mike
Brings up a lot of choice.
Highest rated seems to be the Kingpin Components tap with ignition cut out on it, rather than a ball&spring type.
Me? I don't have one so this 'choice' is purely through reading the various comments made on the forums.
From an engineering perspective,  a full flow tap has to be better than a 'vacuum' controlled ball valve, but reality is probably that there is no real concern with using either.
Hope this helps,
George.
In reply to by george_farenden
Hi George, thanks for your reply. I have seen these and read various articles on the forum, but would prefer a simple turn on / off type without the long handles (not NRV type). One or two neat ones on e/bay but as said, all seem to have reduced bore.
I like them as they keep me in a job. So far 4 engines in the last 12 months. One was a mechanically operated tap.
I won't rehearse the obvious objections to taps.
Last winter I fitted the Holland Norton Works anti-wet-sumping valve and have found it entirely satisfactory so far. It is very nicely made and appears well thought-out in detailed design; more details here (you will need to scroll a long way down, or search for "#H08": https://www.hollandnortonworks.eu/en/exclusive-commando-parts
To answer your question a reduced bore is fine as long as you are sensible.
Look at the size of the hole in the oil junction block, and the inside diameter of the metal pipe, then look at the size of the drillings in the oil pump itself  - these are massively reduced in comparison to the ID of the hose that comes from the oil tank.
Consider the Pingel valves, they are a little spendy, but superb quality, flow well and are not prone to leaking.
In reply to by grant_tiller
Thanks Grant. I did consider the oil flow bore within the engine but being no expert was a bit wary to try it without some advice from the better qualified! I will check the Pingel valves - never came across them in my searches.
I also refer to your website occasionally - lots of useful info. Keep it up! Cheers, Mike
Looking at this with interest.  Has anyone tried the RGM automatic non-return valve, or have any experience or advice on this?
In reply to by roger_jordan
Hi Roger - I have an RGM NRV on my road commando. I only fitted it last year and have done very few miles since but seems ok so far.
look up Magneto guys, tap with ignition cut out safety facility
I remember reading somewhere here that a member made a shutoff valve that used the ignition key.
When you shutdown the bike you removed your ignition key and used it to turn off a valve in the oil supply line.
The brilliant part of the conversion was that with the oil supply valve shutoff with the key, the key could not be removed until the valve was turned back to the on position.  This prevented starting the engine with the oil supply shut off.
Mine is wired to the horn. If I forget to open the oil tap the horn sounds when I switch on the ignition. I used the microswitch on the oil tap and a relay to energise the horn. I have electronic ignition and did not fancy wiring the switch in to that. Pazon systems are prone to frying if you get it wrong.
Dennis
On the Velo, I have their automatic anti-wetsumping valve. Oil leaks through it.
The two BSA unit singles has the original anti-wetsumping .valves. They wetsumps.
The Vincent has a manual tap, which leaks slightly. When forgetting to open it, you can ride a few of miles with no ill effects as it has roller big end bearings..A Norton twin had not survived.
The Manx wet sumps slightly, but I always change oil between races. No problem.
The 16H is rarely used, so no big problem draining the crankcase before starting it.
The 650SS blew the oil seal so that most of the oil in the crankcase filled the primary case.
