Hi, I've a 750 with high compression head, quick action throttle and a pair of handed 930 concentrics.
Main jet 220. Needle jet 106 which are both correct according to Haynes manual.
The throttle slide however is 3 1/2, but according to manual should be a 3.
Will this affect anything does anyone know?
It was getting harder to start so stripped carbs for cleaning.
It seems to be running a bit rich if anything.
Thank you for your help.
There's a discussion here: …
https://www.accessnorton.com/NortonCommando/general-amal-carb-question.32695/
that should answer your question.
