gearbox sprockets
in the process of stripping things down to fit a new gearbox sprocket to my mk3 850 interstate , one fitted is a 23 tooth , is this standard and should I stick with this size or perhaps change as I see there are a few alternate sizes available
22T was standard and that was only done to lower the revs for noise and emissions. I'd go 21T for everyday use, 20T if you just want get-up-and-go and aren't too bothered about pulling high revs on long motorway trips.
According to the workshop manual, at 7,000 RPM, 20T gives 113mph and 21T gives 119mph. A standard Mk3 will have trouble revving out on 21T.
My MK3 850 had a 20T g/box sprocket fitted when bought from the Kenya police who wanted the acceleration - changed to a 22T to reduce revs at cruise speed and which provides the best balance for my money.
If you have had no issues with a 23 then stick with it, if you need more acceleration the drop 1 or 2 teeth but your revs at high cruising speeds will be higher.
I know they're coming up on a half-century but these are sports bikes, not diesels. They're supposed to rev. At 80mph with a 20T sprocket the engine's spinning at 5,000rpm. It'll do that all day, not that I've seen a Commando cruising at 80 in a long while.
IMO tall gearing is hard on the gearbox - which is the weakest part of these bikes. The loading on the gearbox is higher in general with a large sprocket but, in particular, it's a bigger lever on the sleeve gear hastening all the problems in that area. And getting into top sooner can only be a good thing as it unloads the box.
