Can someone recommend a good machine shop in the Sussex area
Hello all
Can someone recommend a machine shop in the  Sussex area.
I want to have my valves, head, cylinder barrels  checked. and if any works needed to be done on Norton Commando.
Stephen
Hi Stephen
You may get some personal recommendations but you should be aware that the distilled wisdom of dozens of NOC members is incorporated into our Services Database. Just click on the 'Services' menu item above, enter your postcode and engineering and cylinder heads and it will find local service suppliers who have been recommended by NOC Members.
Norman White probably has more experience than anyone, and he's in Hampshire...which is next to Sussex...
Try David Moore based in Godstone, Surrey. https://www.davidmooreengineering.com/
He is very capable and his work is top notch.  He hasn't done anything on my Norton, but has done loads for me on my Ducati including valve seats re-cut for larger valves, guides, small end honing and cylinder honing - so I can highly recommend him.  He only builds and repairs engines.
