Filling the Gearbox with Gear Oil
Profile picture for user ronald_wellman
If gear oil is added through the large circular opening in the outer gearbox cover will it distribute everywhere it needs to be?
(and sometimes on other places too, depending on how much goes out of the level plug).
In reply to by mikael_ridderstad
That is the answer I had hoped for.  I had horror story images of having to fill through the drain plug opening.
Yes it does,  but it can take a few minutes to find its level so don't keep filling the outer cover right up. Give it time to drain.
I don't actually remove the level plug. I have a stainless screw and in good light the tip is quite visible through the inspection cap, as is the oil level.
I will take my time filling the gear box leaving enough time for the gear oil to distribute.
I have often thought a fill plug on the top of the gearbox shell would be much more convenient. Filling the gearbox is a PITA.
Not really, easier than filling the forks. Filling the gearbox is even easier if you use this -
https://www.commaoil.com/passenger-vehicles/products/view/550
This seems to be the oil of choice these days, nothing wrong with EP90 but it is thick on cold mornings.
.. of old gearbox oil bottles with the pull-out flexible tube which I fill with the appropriate oil for this sort of job.
