Phoenix SU carb conversion
Hi
I bought a Mk3 with this kit on it (An SU Hif6) runs well just wondering if anyone else is using it, general discussion, ram pipes in use, air filters , settings pro's con's general experiences
thanks
mike
The Phoenix Engineering kit was the SU carb mod that was available back in the day. Others have fitted SU's but have had to make the manifold (quite a squeeze to get the carb in) Phoenix shortened the dashpot top to get it under the main frame tube. The supplied air filter with the kit will be long gone now. (it was a spring stiffened foam job) so an K&N is usually pressed into service. Set up is dead easy, a five minute job. I have the original set up notes if you want a copy. A thin sheperds crook shaped pipe on a syringe makes topping up the dash pot easy. Use loctite on the manifold to head screws.
Pros. No more carb balancing. or tickling carbs so your riding gloves should stay clear of the stuff they now call petrol. More M.P.G. I regularly exceeded 80 mpg when touring europe with a friend.
The  previous year i recorded 90mpg in switzerland, much to my amazement!
Cons. It will send your exhaust header pipes blue, in just a few minutes as well. You will need to use the choke, to start and until the engine is warm enough. The petrol pipe spigots (there are two, one on each side) have no barbs, they are just plain brass pipes. You must wire the fuel pipe clips together around the back of the carb to stop the fuel pipes coming off the carb (happened to me a few months ago, lucky not to go up in flames) modern Petrol is more aggressive at leaching the plastisier from fuel pipe, causing it to go hard. Replace the fuel pipes every year or use ethanol resistant pipe like tygon.
I have the original phoenix instructions too, bike currently has the ram pipe open with some mesh over it, wouldn't mind a look at a filter in use if you have one. Not topped the dash pot up yet, does low oil affect the running ?
In reply to by michael_bradshaw
Yes it will. The oil acts like an accelerator pump enriching the mixture by preventing the throttle piston flying up too quickly when accelerating. SU recommended engine oil  #30 or 20/50. The thinner the oil the less rich.
had one of these for many years on my 750, found it a vast improvement on twin Amal set up, similar performance, but smoother running and better miles per gallon. however all good things come to an end as needle jets wear and mixture changes over many miles and years, till eventually I had rich mixture at tickover and very weak mixture at 60/70 mph. cured richness with new jet but could not solve weak mixture higher up range which was causing overheating, suspect it was no longer raising needle as it should. gave up on it and fitted single Amal.
To sum up great till it wears out, so watch out for very hot engine as a sign.
Martin.
I took mine off & have it in storage, in case I ever decide to go back. Spoke to Phoenix a few times, but then they moved & I've no idea what happened to them.
I found that if it wasn't run to 'empty' after a run it could be a pig to start the next time used. Mpg was excellent, over 300 miles from an interstate tank - the carb runs very lean hence the blueing. I  finally got fed up with the heavy throttle action & throttle cable fraying at the carb, interesting when it jams, so switched to twin Amals. Somebody in the NOC has a neat way of avoiding the fraying problem (saw & spoke to the owner at a rally) but I forgot to take a photo or note his name!
IIrc, low oil in the damper results in more backfiring on rundown (needle bounce) - but it's been off for 10 years or so, so I'm a bit vague on that. Topping up is a pita due to the top fouling the spine & need to remove the tank.
There's a Haynes manual for the SU Series &  of course Burlen for parts.
Just my 2 penn'orth, experience of others may vary.
I have a quadrant fitted to the carb throttle arm that gives the cable a much easier life and easier action. I don't have to remove the tank to top up the dashpot. Just unscrew the cap and get the syringe pipe in there. Will post a photo tomorrow
I bought a Phoenix conversion many years ago now (see image attached) and used it for a number of years on my Commando. It did exactly what the HIF was designed to do and ran very much towards the lean end of the spectrum. As written above by others, plus one or two from myself:
(1) Quite dificult to start
(2) Very economical. On the way to the Kristiansand rally in Norway we were on a tighly enforced 80kph limit for most of one day heading South by Oslofjord and it used an unbelievably small amount of fuel, towards 100mpg
(3) I solved the dashpot problem by drilling a small hole in the side and injecting the oil via a tube (see image attached)
(4) You have to keep the dashpot oil topped up or acceleration will drop off
(5) I had to fit a Burlen valve kit into the carburettor butterfly in order to get rid of the annoying popping on the overrun
See the following references in Roadholder:-
Roadholder 104, Jul 1982, p10, Phoenix Motorcycles
Roadholder 148, Nov 1989, p28, Fenner, D.
Roadholder 150, Mar 1990, p30, Dixon, I.
Roadholder 150, Mar 1990, p31, De Havilland, J.
Roadholder 196, Nov 1997, p41, Heitmann, H.
Roadholder 199, May 1998, p43, De Havilland, J.
Roadholder 205, May 1999, p42, Seignot, M.
Roadholder 231, Sep 2003, p38, Grimmett, C.
I seem to recall that there was talk of fitting a fuel pump to overcome the starting problem. It may have been put into Roadholder - possibly one of the references above; I haven't checked. In the end, I went for a Mikuni instead.
Thanks for all your help, the bike's only done 24k , so i'm sure there's plenty of life left in the carb!
As promised a photo of the cable quadrantCable quadrant on carb
Hi
Is the quadrant 'off the shelf' or did you make it, interested in one of those
The quadrant is of my own manufacture. I'm not sure if Burlen (who now own the SU brand) supply something similar.
