Fitting of Isolastic gaiters
Does anyone have any tips for fitting of isolastic rubber gaiters (I.e. how to persuade them into place without damaging anything)?
Had a half hearted attempt at it last night and thought I could benefit from asking!
Thanks Keith
Hi Keith,
I`m going to be fitting some to my MK3 commando soon as part of my rebuild, my thoughts are Red rubber grease or Silicone grease which shouldn`t affect the rubber. This should aid the fitting.
Kind regards,
Ian
Yes,
Have some of both; I was wondering if careful use of an air gun might also help (not so hot as to damage the rubber, though)!
The gaiters for the isolastics are perhaps the best way of keeping any rainwater and road-dirt inside the machanism.  The isolastics are available from certain suppliers with stainless steel fittings.  If don't intend to ride the machine in wet weather they don't really serve a useful purpose; they obscure necessary adjustments and hide any corrosion.
Alan Sessions has been helping me with my MKIII; he turned them inside out, then just held the outer edge & rolled them on!
Cheers Mike
Not really a "proper" fix I know, but confronted with the old gaiters perished and a need to change them out quickly, I carefully slit one side of a new gaiter open such that I could just fit the resultant C shape on around the adjustment, once the gap setting was all finished, and then very carefully Superglued the cut faces back together again. Worked a treat. That was a temporary fix I did about 12 years ago... I would challenge anybody to spot the difference - and it has survived numerous further vernier adjustments since..
