May sound stupid but how to cut these cleanly ? Roy.
If Al of Skid Factory is any…
cutting stainless steel oil pipe
hello yes the best way to cut stainless steel oil pipes is with a stainless steel cutting blade in your angel grinder,and do watch them fingers please ware protective gloves and eye ware The stainless steel blade is thinner to the normal steel cutting blade, so please beawear of this and fitting blade on a angle grinder do not over tighten the locking nut on your angle grinder it only needs a nip up nothing more than this, its self tightening you not get the get them undone if you do over tighten yours anna j
A very long time since I've…
A very long time since I've tackled this sort of job, but my memory is that a hacksaw will work provided that one firmly tapes round the site of the cut and saws through the tape.
The braid will open up when…
The braid will open up when cut. I was advised to wrap the cut position tightly with a strong tape then cut through with a cutting disc in a Dremel.
I second that about wrapping…
I second that about wrapping the hose tightly with the likes of insulating tape where you wish to cut. Don't attempt to cut it without doing that.
A Dremel could be used, but very thin cutting blades specifically for stainless steel are readily and cheaply available for disc cutters; 4" or thereabouts.
You will need to lightly support the hose in a vice close to where the cut is to be, to prevent it from moving around when you make the cut.
Ian
Low-Tech.
The taping is important, but it's quite possible to cut the hose with a fine-toothed hacksaw. A small amount of 'feathering' of the braid is not a problem as it has to be opened in order to place the olive anyway. Don't forget to put the nut on the hose first though.
Braided lines
Think I'll try a dremmel. Taped first and put a bolt up the pipe to make it easier to hold in vice to save flattening. Thanks to all, Roy !!
Tin snips
I have struggled cutting braided lines in the past. I tried a different method to the ones listed above and found it quite satisfactory.
First of all, securely wrap the line where the cut is to be made using pvc tape. Apply the tape so that you are cutting through it as well as the line.
One single cut using a pair of 'Gilbow' tin snips and the job was done. Minimal fraying and a clean cut. Have a look on Ebay (don't know how to paste a link on here - sorry!)
Braided wire cutters
Look on Amazon. Draper Expert 57768 wire rope and wire cutters. Bargain at just over a tenner. Will cut control cables and braided brake lines without fraying.
Tin snips v. Wire cutters
I think that the wire cutters referred to seem to have too small a jaw opening to cut straight through oil lines.
I have used the tin snips on braided lines with an o.d. of 20 mm.
If Al of Skid Factory is any guide, use a cutting blade in an angle grinder
