Piston ring orientation
Hi all - I am in need of advice regarding ring orientation. I am installing new Gandini ring sets as supplied by Andover on original AE Hepolite pistons .
The second compression ring - the central one located between the top compression ring and the oil control ring - has a rabbet around the outside edge on one face . Should this rabbet face up towards head or down towards crankcase ? I am thinking down to act as scraper but I am uncertain.
Thanks in advance for any input .
Cheers - Richard
Should have looked closer - ring was marked “top” - indeed rabbet faces down . IIRC “ rabbet “ is “ rebate “ on the other side of the pond.
Once again divided by a common language!
