gearbox leak 1973 750 roadster
Hello All,
              My gearbox has a leak from the kickstart shaft if I take off the outer cover to replace the seal 04-0005 , I,m thinking I might just as well
change the gear change one as well 040006 . Having never done work on the gearbox before I was wondering how much of a job it is ? any precautions to be observed all tips welcome .
        thanks
Just follow the (proper) workshop manual.
There are X section rings to replace the O rings which work better in my experience.
Thanks Ian will do , i have ordered the x section rings and thanks for a prompt reply.
