Hello All
I have a good understanding of how the electrics of a bike or car work (or don't work as the case may be) and I am planning on fitting relays for horn, ignition, dip and main beam - even though I have a new wiring harness as I wish to take the load off the switches which are old and give the best chance of the full battery (18ah Lucas Gel type) reaching said items. Also I wish to run returns (positive earth system) back to the battery for the best chance lights in the dark and sparks in the cylinders. The problem is I do not know what size of wire as in gauge or mm to use. I would like also to know the size of alternator A/C wires as i need to extend them to meet the solid-state modern type reg/rect. unit which I have mounted between coils to keep it cool (Boyer ignition so no condenser there) I like to fit wires with plenty of spare current carrying capability as in future I hope to fit larger alternator and an Alton electric start. If thisis done the main 35amp fuse can be reduced in amperage but what would you recommend for the 5 fuses I plan to use (modern blade type for easy availability at petrol stations etc. if needed)Main harness fuse?Ignition coils and boyer fuse? Dip beam fuse (55watt halogen)?Full beam fuse (modernhalogen)?Horn? Thankyou for your time and knowledge KarlHi Karl - ref the fitment…
Hi Karl - ref the fitment of an Alton Electric Starter - I have one fitted to my Commando - it works superbly. You mention fitting a new alternator when you fit the Alton starter. FYI a new alternator is supplied as part of the Alton kit (together with all the required starter cabling, solenoid etc.). The alternator is of a special 'slimline' design rated at 150w - no other alternator is really suitable as the width of other types would preclude the starter fitment. i.e. don't buy any other type.
Previously Chris Grimmett…
Previously Chris Grimmett wrote:
Cable in the UK is rated as follows:- 0.50mm2 - 3A 0.75mm2 - 6A 1.00mm2 - 10A
There is no reason why you cannot use standard mains cable rated at the appropriate current if you wish. I find 7-core trailer cable very useful indeed for rewiring bikes. The central core [2.00mm2 White] is usually rated at 17.5A and the remaining 6 conductors are rated at 8.75A each. I use that white central core as the earth back to the battery. All this means that you are throwing the standard wiring diagram and colours out of the window, so make good notes on what connects to what. Also, use flexible twisted strand cable and not solid cable such as twin and earth as used for domestic lighting and power wiring.
I don't know the current drawn by an Alton electric start but it is going to be in a different league to those discussed below. If you are trying to future-proof your rewire now, you will need to run some starter cable of considerably higher cross-sectional area. I am taking an educated guess that the Alton conversion comes with a solenoid but you could wire one in now, fit the starter motor cables and leave them safely terminated until they are needed.
Regular readers of the message boards will know that I think chassis earth returns are a work of the devil and a failure waiting to happen. It's sometimes difficult to avoid but it was pointed out to me long ago that soldering cables is best avoided wherever possible. The heat involved can brittleise the copper and result in fractures close to the soldered area. That's why the aircraft industry settled on wire wrap years ago and the automotive industry uses crimp connections. Your alternator is unlikely to kick out much more than 190W = ca. 15A so extend its wiring appropriately; you can look at the existing alternator wire dimensions to get an idea of what is required. I find that it is a much better idea to have the various sub-sections of your bike's electrical system fused separately. If trouble occurs, it makes fault-finding a lot easier and you can then always run with the offending part isolated if an immediate repair is not possible. That's provided it's not the ignition of course. Your choice of car blade fuses is a good one. They are compact, easily obtained and come in a variety of ratings - e.g. 2, 3, 5, 7.5, 10A and upwards from there. For the the headlamp fuses, a 5A is probably OK as they always blow well over the rated value but I use a 7.5A to be on the safe side. Ignition coils and the Boyer should not need much more than a 3A and horns vary but are large consumers of current albeit for a short while - use a 7.5A or even 10A fuse. If you run a separate fuse for side lights and indicators, a 5A usually suffices. A meter will confirm the individual fuse requirements for the various parts of the electrical system.
Finally, it's not a bad idea to retain a master fuse right back near the battery itself and something large like a 35A will do for that.
Al Oz strikes again.
90% of the above information from Mr Grimmett is technically very good and worth following. But the use of any old trailer cable and/or mains cable on any vehicle is rubbish!!. I would use none of the above cables on a British Vehicle (well perhasp to lash up some speakers on a 70s car!) Cable is relativle cheap, 90% of the cables on a British motorcycle have the same current capacity so choosing correct vehicle wiring does a correct job. Every time you add wrong/different coloured cable to your bike you multiply the chances of the next breakdown sort out being horrendous. Casual wiring gives casual results. DO IT PROPERLY!
There are something like 10 basic coloured cables used on a British motorcycle. If you stick to them, then the next time your electrics break down it is very easy to sort out the problem. If the rear light fails (due to a wiring problem) then standard colours tells you it will be in the Brown and Green wire. If it is on Mr Grimmett's bike you won't have a clue which wire it is unless he is standing there with the diagram! How many of you carry the diagram?? Try remembering a few basic colours, much easier. PS Don't buy a bike from Mr Grimmett else you won't have a chance with the electrics! Keep it simple stupid.
Basic British motorcycle wiring uses 8.75 Amp wiring 14/030 while the main power feed can be 28/030 17.5amp. These days we are going over to thin wall cable!!! This is the same wiring but is rated next size up!! ie 28/030 becomes rated 25AMP. Clever huh? All this does is the same copper passes more current, gets hotter (warmer) and you have slightly more voltage drop.
Why do you want fuses in every circuit? why are we expecting faults all over the place? What are you protecting?
The only real need for a fuse is in the main battery feed, this stops the power in the battery getting into the bike and making it burst into flames. Any added fuse will be adding extra connections, wires, fuse holders etc no need. Once you start blowing fuses due to dodgy wiring it is time you sorted the thing properly.
So There'
Al Oz.
Eyop Karl, so nar tha nose…
Eyop Karl, so nar tha nose,thaz bin teld ,so gerron wi it.
Good Luck,Mel.
its all done an started se…
its all done an started second kick!!!! it ran for about a second but it counts there was inturnal combustion.
got carbs to sort out but its all working.
it has 60 feet of wire 4 micro relays (ebay very cheap) a 20ah lucas gel battery and a fuse box with 6 blade fuse and (a single coman input form battery) redLEDs for each fuse that light when fuse blows (positive earth an works fine)(£10 ebay)
also a wypac cristal glow headlight which is like modern car lights with clear glass an shaped reflector. i fitted two to my old landrover an was most impressed so am hoping for good light on bike. They come sold in pairs from Paddock Landrover Spares (look it up on google) of about£40 the pair make sure you get the ones with built in sidelights tho.
lots of other usual type improvements to so hopefully it will be nice bike when fettled an set up.
an the suns gone away now and thunder an rain is back lovely!
I agree with that Al, I wa…
I agree with that Al, I was just about to put a blade fuse box in mine then I thought, "Hang on, that's just more mechanical connections, more complexity, and more to go wrong!"
So I replaced all the duff wiring and connectors, and where I could, I soldered and heat shrunk the lot! Time consuming and harder to fix if it goes wrong, but far more durable.
I did however stick a 180W conversion, a "power box" (potted heat sunk regulator/rectifier), and a Pazon ignition on, to help the new brass slide Amals cope. Unlike my wallet, which is weeping quietly in a corner somewhere...
It may also be worth pointing out that if you are going on an uber fusing mission, you should ensure that all of your earthing points/wiring are good, and that all your connectors are good, and that you have no potential short circuits.
The devil is most certainly in the detail.
Personally, I would concede that perhaps the odd "zone" fuse may be useful, but not perhaps necessary.
Jack
On the subject of Land Rov…
On the subject of Land Rovers, my 1952 model has one fuse. In the Workshop Manual, it says in the event of the fuse blowing, fit a bigger fuse. I kid you not. Gordon.
Gordon i had a modern 1962…
Gordon i had a modern 1962 landrover with 2 fuses (high tec stuff) as the wiring was the old rubber covered type one day it had enough of be electrical string and turned into afire lighter! The flames burned happy as the driver choked on the poisonous fumes and the two fuses refused to do as their name implies and copper glowed very brightly. Being the old pull a cable to stop type diesel i pulled off the battery leads and drove the portable barbque home (happy days).
so more small quicker to blow fuses are the best way just look in the fuse box of any modern vehicle.
Glass fuses or not as easy to come by these days as they once where and the metal ends tend to sperate form the wire so even that spare fuse you have carried around for years may not work when the time comes.
I once used to do offroad racing with landrovers (yes grown men will race anything!!) and as we travelled at about 40mph (no realy big tune V8 3rd gear foot on the floor) at night in dense woodland the single fuse (not my idea the mate who fitted the lights wantted it to be simple) fused. The colour of adrenerline is brown and the crash was heavy and painfull (to man and wallet). Motorcycles look very odd with roll cages (think that BMW scooter thing) so if the fuse or bulb should go as you ride along its nice to flick the switch to the other beam before you hit something.
If I solder a joint that may flex an stress the wire i get the bit of the cable tie you cut off and bin normaly then making sure it is loger at either side than the joint rap it tightly to the wire like a split cocering the area both sided to support the wire but allow some flex. Use heat shink on joint first then fit splint with self vollcanizing rubber tape. Also wape spade an bullit connetions with self vollcanizing tape keep water out and they work reliably for years even when you put them underwater or in mud oil or cow muck (i recommend a landrover for this as they are more tollerent than Commandos of that kind of treatment)
Karl
People seem to worry about…
People seem to worry about copper becoming brittle when it has been soldered. It shouldn't if you have used the correct soldering iron, which won't get anywhere near hot enough to affect the copper - e.g. don't use a wacking big 100 watt gun iron or a blowlamp! 25 watts should be more than enough.
My Dad was an electrician in the 1950s and early 60s- both auto and domestic -and as an auto electrician he used to be involved with HGVs, up to the "Mighty Antar" tank transporter and the old Mass Radiography mobile X-ray units. I regard him as an expert and he always recommended soldering the nipples on when using bullet connectors. Exposed wiring in bikes tends to oxidise and can end up blowing all your bulbs ifa connection to the battery gives up even briefly when you're running with lights on.
Using a proper earth wire to allelectrics is a very good idea. That way you don't need to destroy paint on your preciously expensive, stove-enamelled frame for one thing! Less voly drop too. Just keep the colour code correct (Lucas used red for positive earth 6V and 12V) You could use an earth block in the tool tray underneath the seat if you wanted, but a multi-bullet connector works too. A 2-way can have one in and three out. (3-way has 1 in, 5 out) A relay needs a seperate "earth".
Cheers, Lionel
PS. By "exposed wiring" I…
PS. By "exposed wiring" I meant the copper core of course!
Cheers, Lionel
Hello why are you still us…
Hello why are you still using old tech , you all need to take a look at Electrexworld.co.uk and try out there new self generating electronic ignition and lighting system , comes all as one kit for less than £300 you can fit this a forget it , its will go on working with no fuss and its reliable only one moving part, this all fit in the alternator side , you Dump every thing that was there before, its far better than Boyer or Pazon or any other Electronic ignition system the Kit you need is STK-102D Fits Commando and Dominator Alternator Models Only , So Check this Out, Yours Anna J
Anna - are you saying that…
Anna - are you saying that this miracle electronic ignition you mention can replace all the wiring on a bike? I wouldn't think so - this post is about wring and fuses, not electronic ignition.
Cheers, Lionel
_______________________
Cable in the UK is rated as follows:-0.50mm2 - 3A0.75mm2 - 6A1.00mm2 - 10A
Regular readers of the message boards will know that I think chassis earth returns are a work of the devil and a failure waiting to happen. It's sometimes difficult to avoid but it was pointed out to me long ago that soldering cables is best avoided wherever possible. The heat involved can brittleise the copper and result in fractures close to the soldered area. That's why the aircraft industry settled on wire wrap years ago and the automotive industry uses crimp connections.Your alternator is unlikely to kick out much more than 190W = ca. 15A so extend its wiring appropriately; you can look at the existing alternator wire dimensions to get an idea of what is required.I find that it is a much better idea to have the various sub-sections of your bike's electrical system fused separately. If trouble occurs, it makes fault-finding a lot easier and you can then always run with the offending part isolated if an immediate repair is not possible. That's provided it's not the ignition of course.Your choice of car blade fuses is a good one. They are compact, easily obtained and come in a variety of ratings - e.g. 2, 3, 5, 7.5, 10A and upwards from there. For the the headlamp fuses, a 5A is probably OK as they always blow well over the rated value but I use a 7.5A to be on the safe side. Ignition coils and the Boyer should not need much more than a 3A and horns vary but are large consumers of current albeit for a short while - use a 7.5A or even 10A fuse. If you run a separate fuse for side lights and indicators, a 5A usually suffices. A meter will confirm the individual fuse requirements for the various parts of the electrical system.
