Can any one tell me if a kick start lever for an AMC box fit a Lay Down box
many thanks Ian
commando kick start. fitte…
make sure the one you fit…
make sure the one you fit will clear the silencer
both of these have the same spline
p1010003-15-jpg
and this is the new foldin…
and this is the new folding one that I just fitted
p1010001-18-jpg
How do you maintain the to…
How do you maintain the top nut at sufficient tightness to hold the peg but not so loose that it flops, John? I've had do do mine u tight ad leave it permanently sticking out. It kept coming undone. George
mine seems fairly tight at…
mine seems fairly tight at the moment, just a lock washer and domed nut.........but give it time.
the kickstart on the thunderbolt has a spring behind a ball bearing , which engages in an indent, seems to work well
OE Commando kickstarts hav…
OE Commando kickstarts have a ball and spring detent as well. Some pattern don't.
commando kick start. fitted to laydown gearbox cant remember what model or year it fitted commando wise.
Barry
kick-start-jpg
