If your interested in seeing my Electra undergoing restoration I've create a page for it here... (nothing commercial...)
Hi Ian, You are doing a fa…
Hi Ian, I just found anoth…
Hi Ian,
I just found another picture of yours that I'd like to comment on. Hopefully, Peter Holland has spotted it earlier for you - but just in case -
https://www.facebook.com/photo.php?fbid=10205961998676177&set=oa.1044636755563010&type=3&theater
This picture shows your clutch release mechanism. I would not expect the cable to have an adjuster at this point. The cable adjuster was situated in the cable itself, about 3" away from the lever. (I think) all Electra and post 106838 Jubilees & Navigators had the same method of cable adjustment. The note of caution is because I do not know exactly when Norton chose to use an in-line adjuster. My guess is that the change of gearbox innards & crankcase castings was a good change point.
The earlier bikes did have the cable adjustment at the gearbox end, and a right pig of a job it was too. The move to in-line adjustment was sensible and overdue.
Andy, I would be really in…
Andy, I would be really interested in seeing a photo of the engine baffle. I thought that part, when I found it on the bike was a bit strange, so duplicated it in new material as it was all I had to go on. Fortunately it's easy to remove so I can easily replace it. Peter mentioned the clutch cable earlier on the thread and agrees with your comments. I have the correct cable for my engine (EL/364) which was one of the earlier ones I believe.
As for taking photos etc. it takes hardly any time at all. I keep an old digital camera on my work bench and snap away at things I think might be interesting to others like yourself who might be building a lightweight as there's not a lot of information out there about them. When the card on the card gets full or the battery dies then it's time to download them and make a few comments. I really don't mind doing it and it's nice to get feedback from others as I progress - the thing about the engine baffle being a prime example. I'd never have known if you hadn't brought it up.
And for Boo Cock, and also my Wife and others - I did it - I put the mileage back to original 21758 on the odometer.
Ian
Moving on to the electrics…
Moving on to the electrics; I bought a new Wipac starter/dip/horn switch using the part number from the parts book. The problem I have though is it came with 5 wires but the wire diagram shows 6 coming from the switch. It looks like the white wire in the diagram is missing from the switch and there's no place to fir one. Any ideas? Is there a 6 wire switch available?
Looking again at the switc…
Looking again at the switch am I right in thinking that the red button is the starter the toggle is high/low beam (though H/L is on the head light switch) and the black bottom on the bottom is the horn? It's not making sense with the H/L switch on the headlight shell. The bike also came with a switch on the left handle bar which someone in the past has been spicing wires in to. It actually has all the colours I was expecting but the white and yellow have been disconnected and twisted together and other stuff spliced in.
p2130054-jpg
Ian, A little while since…
Ian,
A little while since I wired my tricon switch.
H/L on the headlamp shell selects either headlights (H) or just parking lights (L).
With H selected on the headlamp shell, the toggle on the tricon switch will select either Hior Lo beam. That accounts for three wires to your tricon switch.
The red button on the tricon switch usually does the starter motor. Red button earths the starter wire to handlebars for on.
The black button on the tricon switch does the horn.Black button earths thehorn wire to handlebar for beep.
This accounts for five wires from the tricon switch. If there is a 6th wire shown, I'd suggest it is an earth wire from the headlamp shell to the tricon. Not absolutely essential, but a much better path for the earth current from the horn than through the greasy steering head bearings or handle bar clamps. Your winker wires (if you fit them) have to go into the handlebars. I took an earth wire in too, and terminated it to a small nut and bolt through the handlebar and invisible under the left hand rubber grip.
The winker L/off/Rswitch was fitted on the right side by Norton.
Don't recognise the switch in your photo.
Ergonomically, the switchgear is a catastrophe.
Pull in the clutch and thumb the starter when you stall? Not for any human I've met. Reach the winker switch with your throttle thumb? Only if you can keep the throttle open with your little finger only.
Have fun.
Thanks Peter. Sounds like…
Thanks Peter. Sounds like I wired everything up correctly and just need to find a indicator switch for the right side. Nice to get that confirmed. H/L for head and parking - who would have thought? All makes sense now. The ergonomics of it all does seem a bit odd.
Wiring is coming together nicely, not that it's very complicated. All the components are checking out well so not expecting any initial problems with the system.
Does anyone know where I can get copy of an owners (not workshop) manual? I would be interested in seeing one.
Ian
Ian, Looks like I should h…
Ian,
Looks like I should have looked at the diagram. The starter solenoid need to receive 12 volts from the red button to work. This means the red button needs two wires, not one. That makes six wires in total needed to the Tricon switch on left of handlebar.
Sorry for the wrong information. This diagram courtesy of Tony Ripley. Not the full, original, Norton circuit diagram.
Thanks Peter. Sounds like I wired everything up correctly and just need to find a indicator switch for the right side. Nice to get that confirmed.Ian
electra-circuit-iss-2-pdf
Previously peter_holland1…
Previously peter_holland1 wrote:
Ian,
I don't think you will find a Tricon switch with a switch for the starter other than the one where the RED button goes to earth on the handlebar. The other way round the problem is to fit a relay, which is pulled in by the Tricon earth switch. This relay then putting a LIVE onto the starter solenoid. This type of starter solenoid has its energising coil going to earth inside it hence you have to supply it with a live.
Al O
Previously andy_sochanik w…
Previously andy_sochanik wrote:
See attached for the correct looking Clutch cable
Anfy S
Ian,
I wish you had put these photos up eight years ago when I started my Electra rebuild. It is a travesty that the NOC have never produced a video of a lightweight rebuild. Your photos are, in many ways even better.
I can see from your photos that my clutch is probably more worn than I thought. I'm not sure I saw any cork inserts on the inner race plate as you show. Something else to check before summer and might explain why it slips.
I see your clutch cable has an adjuster where it enters the gearbox. This is a clutch cable from the 'early' Jub and Nav. All clutch cables on later gearbox lightweights have an adjuster mid cable. If it works for you, fine, but you will be caught unawares if you buy the original replacement.
_______________________________
My '64 Navigator, post-106838, has the clutch cable adjuster about 3 inches along the cable...but at the clutch end, not the lever end (see pic). The pic put up by Andy S. shows the adjuster at the lever end, which makes more sense. So what's with my cable? It seems neither one thing nor the other.
Terry
clutch-cable-2-jpg
I've added a few more pho…
I've added a few more photos to the web page.
Here's a not so good photo of my side stand. Apart from the missing foot, isn't it supposed to be straight?
p1010332-jpg
I'm needing a bit of help…
I'm needing a bit of help here as the manual is no use for this question.
Two steel lines go into the bottom of the engine on the right side of the bike; one is the feed from the oil tank and one is the return from the scavanging back to the tank. Which is which? When I took the lines off of the bike the feed from the tank went to the right (or outside) line. Just want to make sure before I start it up that the lines are correct. In the photo it would appear that the hole on the left side where it mounts is bigger than the right which also makes me think the left side (inside)line is the return.
p5030379-jpg
I'm pretty sure that on m…
I'm pretty sure that on my jubilee, the oil ways lined up with the tank outlets without crossing over which made the inside pipe the return, but I must admit to connecting it up with clear pipes for the first fire up to make sure I'd got them the right way around!
Hi Ian, Dan seems to be ri…
Hi Ian,
Dan seems to be right.
http://www.nortonownersclub.org/noc-chat/technical3-light-twins-forum/524944964?b_start=0#694115609
Thanks guys, it makes sens…
Thanks guys, it makes sense as you say that the lines match up without crossing over.
Peter - that link doesn't appear to work, can you re-post it?
Previously Ian Easton wrot…
Try this Dan.
It just worked for me and relates to the same article.
http://www.nortonownersclub.org/noc-chat/technical3-light-twins-forum/161809937?b_start=0#943441151
Cheers Peter
Worked that time for some…
Worked that time for some unknown reason - Thanks.
Some new photos added. The…
Some new photos added. The chrome work came back from the platers...
https://www.facebook.com/media/set/?set=oa.1044636755563010&type=3
Ian
Looking good! On the jubil…
Looking good! On the jubilee and Navigator the rear brake rod goes under the rear axle?
The photos I have of the N…
The photos I have of the National Museum's Jubilee show the brake rod going under. The Electra is definitely over.
I am fairly certain that t…
I am fairly certain that the Electra rear hub/brake is the same as the Dominator and very different to the Jubilee/Navigator item. Even the actual swinging arm is different as well but as I have never had an Electra I don't know all the differences.
Excellent pictures.
Patrick.
Yes the Electra has the sa…
Yes the Electra has the same hubs as it's bigger brethern - all that extra power compared to the Navigator and Jubilee has be leashed up somehow you know
Hi Ian, A little while sin…
Hi Ian,
A little while since I looked at the progress and pictures.
Re Speedo.
I've already said that the headlamp shell with red tell-tales comes from an earlier bike. Also, that the condition of the engine internals is far better than 22k miles would suggest. Your speedometer, with the external illuminating bulb, is of the same era as the headlamp shell. Your original speedometer would have had an internal bulb for illumination. I speculatethe original speedometerwould have had very few miles on it when replaced. Sorry if this is bad news.
Your chromer has done an EXCELLENTjob. Get plenty of waxy rust proofer on the inside of the mudguards. The damp can get inside the rolled edges. I painted mine with hammerite silver on the insides as soon as they were back from the platers. Then Waxoil. If you intend a show queen then these precautions against damp and stone chips can be ignored.
Still got the dodgy lever on the mainstand I see.
Yes, the sidestand should be straight. NOC had some remade some years ago. Yours is correct, if a lot distorted and worn.
Can't help with the '3' on the exhausts. They look original.
Go easy with the grease points on the ends of the brake cams. I just put a couple of drops of oil in them once in a while.
You may be interested in my Norton Electra rebuild which is being run in the 'Real Classic' magazine, with the first part in the October issue.
If you go onto the NOC website, Yorkshire Branch, Our stories, you can smile with me on my Electra rides.
Well done and thank you for the wonderful photos.
Peter, I'm not disappoint…
Peter,
I'm not disappointed with the information on the headlamp and speedometer, I'm just working with what I have at the moment, but I do appreciate the information so that I can keep a look out for original parts.
As for the main stand - it'll be getting fixed once I get the bike running (soon) and the improvements to the centre stand pivot suggested earlier will get done too.
Yes, I'm very pleased with the chrome work and I'm glad I got it done - well worth it. I like your idea of sealing the seams.
I will certainly check out your articles in Real Classic.
Thanks again for the help/information and encouragement as I'm starting to run out of steam on this project (long story behind it). That's why I need to hear it run before making the changes it needs. It will get finished -I'm not giving up now!
Hi Ian, You have certainly…
Hi Ian,
You have certainly put in a huge amount of work and have produced a superb looking machine. It will be good to get it running and you can then enjoy using it. Don't worry too far about minor details.
Going back to what Peter mentioned on the speedo/headlight I notice that your speedo has the Smiths reference number of 3170 26 1600. I bought a speedo at an English autojumble a few years ago and it has the identical same reference. The odd thing about the transaction was that the seller said it came from a Norton ELECTRA which is an almost unknown model here !. I bought it as it looked identical to the speedo in my 1961 Navigator De Luxe which has the reference number 3153 95 1600 on the dial.
So your headlight and speedo just might be original to an US market 1963 machine as the Electra did not appear on the UK scene until some time later- at least the parts you have are working and come from the same stable. I think Peter is referring to the grey faced speedo. It's amazing the detail differences between Jubilee/Navigator/Electra over their short life span.
Patrick
Peter, I've just read you…
Peter,
I've just read your first part of the Electra article. I feel fortunate to have found one so complete after reading what you've gone through. I did discover on my rear mudguard after it came back from the chromers a complete set of duplicate mounting holes that I should have welded up before it went to chroming. They are about 3 or 4 inches further forward than the correct holes. The odd thing is though they look like they were factory done and not just some guy with a drill in the past. I should have paid more attention to them before sending them off. I'm assuming where the rear mudgaurd mounts that there are spacers that I don't have. I'll make a set up on the lathe. i have to collect my seat too. The guy has had it for 6 or 7 months now and I don't want it to end up like your back mudguard. Electra seats are not easy to come by.
Patrick, Interesting comment about the speedo -you might be right. It would be nice if there were some factory records available about the detail changes.
Hi Ian,
You are doing a fantastic job! How do you find the time to do the rebuild, take photos, upload & annotate photos? Brilliant.
Meanwhile, while looking through your snaps I came across this photo of yours https://www.facebook.com/photo.php?fbid=10208474791814435&set=oa.1044636755563010&type=3&theater
Its the centre stand stop & 'cushion'.
What you have called a cushion, is in fact only a part of the whole. The whole piece was a baffle placed on the engine side of the centre frame channel to stop mud and dirt being flung up behind the engine. It was made from some sort of hardboard.
I have a complete one somewhere & will update you when I locate it. (Still looking for stuff 1yr+ after moving).
