It seems like a simple qestion but as yet I'v not found an answer.
Is there a comprehensive list giving bearing reference/identification numbers for the bearings fitted to Dominators (presumably covering Atlas, Mercury etal) for both engine and cycle parts.
I would prefer to shop at a bearing supplier for replacements rather than a 'Norton'parts supplier, so that I can specify manufacturer.Somewhat wary of eastern/asian supplies.
Help/advisewould be appreciated.
regards JMB
If you don't support your…
See if the info in the att…
See if the info in the attachment is of any use.
I found it most useful for getting bearings from alternate suppliers.
It comes via Bob Davis, Hunter Valley Norton Owners Club....There is a second version further down this thread which may be easier to open.
norton-bearings-doc
Quite right David! there`s…
Quite right David! there`s plenty of reliable parts people. I use RGM and have found them to be more than helpful.
cheers ,Alan H.
Try this attachment......i…
Try this attachment......it should open more easily.
norton-bearing-sizes-bmp
When you find a good one.…
When you find a good one. Fine for Norton parts but not always for consumables....and I use NOC supplies where and when I can.
regards JMB
If you don't support your Norton parts supplier he won't be there when you need him...!
