I've had my Dommie, originally an 88, now with 99 barrel and crank since 1972 and it has always had a tendency to seize the left hand piston, whether with Hepolite or GPM pistons in the 500 barrel or, as it is at the moment, Heplex pistons in the 600.
I've just honed the cylinders and cleaned up the pistons from the latest tightening up. The left piston had scuff marks in four places fore and aft of the gudgeon pin holes (see attached pic.)
I wondered if there might be a clearance issue, so following a suggestion I heated the barrel and pistons to 150?C and found the pistons would slide down the bores under their own weight, supposedly indicating that there is sufficient piston - bore clearance.
I believe some engines had oil holes in the conrods and big end shells to squirt oil onto the bores, but my 1963 engine doesn't have these, and as far as I know it has the original rods.
Is it desirable to have this extra lubrication, and if so how exactly would I go about making the holes in the correct place? Is there anyone who has done this?
copy-of-imgp1710-jpg
Previously simon_ratcliff…
I always take advice from…
I always take advice from the component manufacturers rather than journalists. What do you think would be best for cylinder sealing - a 0.005" (5 thou') or 0.0002" (2 tenths of 1 thou') ring to bore gap? The workshop manual suggests a difference between the worn part and unworn part of the bore of 0.005" to be max. acceptable wear. However, this was written approx. 38 years ago. Why not have a rebore to current recommended tolerances? Rebuild the top end with 0.002" cylinder ovality/wear if you like, but don't be surprised if you have high oil consumption, piston ring blow-by, excessive crankcase pressure, loss of power, oil contamination of valves/combustion chamber/spark plugs and smokey exhausts. It's also false economy as you'll have to strip the top end sooner and have the required work done anyhow. I suppose it depends what your priority is - money, or doing it properly.
See www.cp-carrillo.com for relevant info.
I take your point, of cour…
I take your point, of course.
However, when I last rebuilt the engine, with cylinders I bought newly rebored to the pistons supplied, the results were exactly as you describe for oval cylinders. Maybe the rebore wasn't done right, but the parts were supplied by an expert member of the NOC who insists all was correct. I wonder if poor ring sealing could just as well have been caused by my not running it in correctly.
As things stand at the moment all I have to lose by going ahead with the rebuild is finding no improvement and having to take it apart again for a rebore. But that's not a big job.
Rob's carb jetting......…
Single 1 1/16" 376 Monobloc, 250 main, 20 pilot, 3 cutaway, .106 needle jet, 5-groove needle in middle groove, paper air filter.
With the paper air filter in place this engine is probably going to be runninga little rich throughout most of the range to start with. The manual suggests just a 25 pilot jet. A 20 jet is used by bigger engines with generally bigger carbs.
Plus, unless all the bits are newish, the needle jet will probably also be worn, causing richness in mid-range running. This could be why the original plugs were sooty.
Plus...Plus....Plu... apparently the Ethanol, that has been addedto our petrol, affectsits overall specific gravity and causes original floats to sink a little. Thus causing the carb to be constantly flooding. Just wondering if this and a rich mix anyway, is washing/dilutingthe oil getting to the pistons. Thoughthis surely would affect both pistons.
Rob, I'm beginning to see…
Rob,
I'm beginning to see why you've had the problem since 1972.
Previously simon_ratcliff wrote:
Rob,
There's no need for that. As I said, I take your point.
I've had rebores in the past, just as you suggest, and still the problem recurs from time to time. Probably none of the people who did the work were as good engineers as you, but I'm stuck with who I can get to do it. It's not necessarily all down to my lack of perfection.
Previously phil_hannam wro…
Thanks for your continued helpful thoughts Phil.
I'm confused by your pilot jet thinking though. Isn't a 25 bigger than a 20, i.e. richer? If so, by your reasoning I should be heading in the right direction by going down to a 20. I selected it on the basis of turns of the air screw with the aid of a Colortune. With a 25 the air screw was almost falling out. It does seem very sensitive to pilot settings over a surprisingly wide range of throttle. It often needs full throttle to start, either to give it enough air because it's rich or enough petrol because it's weak, I don't know.
I renewed the needle and jet not long ago so they shouldn't be too worn. At the same time I replaced the brass float with the latest "stay-up" plastic type.
It's definitely been using oil and smoking. The plugs were oily black rather than dry and sooty.
Interesting point about ethanol. I didn't know its SG was lower than straight petrol. Before I went back to a Premium Concentric on the Commando I occasionally had problems with petrol flooding out of the back of the Mikuni. I try to use super unleaded on the grounds that it's maybe less likely to contain ethanol, though I know that varies between brands and which refinery it comes from, but sometimes you have to use what's available at the time. I wonder if that explains why it only happened occasionally? But now I'm rambling off the point of this thread.
Of course the valve guides…
Of course the valve guides could be to blame for an oily combustion chamber.My 1952 Land Rover would lay down a good smokescreen which was cured by replacing the valve guide seals. Of course pre Commandos don't have guide seals, but the guides themselves could be a loose fit in the head or simply just worn.
Fuel can do nasty things. Years ago Shell produced some horrible petrol which hadVauxhall ifI remember giving them the bill for a spate of engine seizures. I filled up my BSA with some out of necessity and it too seized - 12,000 miles after a rebore.
As a matter of course,if I have an engine reboredI go for the lowest available compression ratio pistons. It runs cooler, it's easier on the rest of the engine and it adds a bit of future-proofing. There's nothing like detonation for destroying engines. Gordon.
Rob, I don't do rebores.…
Rob,
I don't do rebores. I was pointing out that without measuring accurately and establishing dimensions you don't know, you are just guessing. Ditto oil pressure. The way you're going about the problem, it may be another 41 years before it's resolved. If ethanol was to blame then every reciprocating internal combustion engine in the uk would be seizing. As you have a single carb then I would have thought you can eliminate carburation, especially as you mention it's been running rich. If you get your barrels checked and also check your oil pressure, then at least you can rule them out as the cause. I'll leave you to go about it in your own way.
Previously rob_bradley wro…
Why fit unknown rings? Do the engine a favour and spend about £40 on a decent set - after you've had the barrel checked for ovality and honed to suit the rings. Peoples opinions are one thing, but there is no substitution for accurate measurements when trying to eliminate possible causes (in my opinion), hope you get it sorted,
Simon.
Unknown rings in the sense that I don't know the manufacturer. +0.030" are hard to find so I've had to get what I can, from Cox & Turner.
What counts as excessively oval? Is 0.002" OK, front-back vs side-side?
Hello Well 0.030 oversize pistons and ring are the Norton motors bracebridge street works recommendations for there over size were plus 10 +20 +30 , the other sizes that are now available are after market over sizes pistons from +20 +40+60 these are the pistons that have been found to be giving Norton Owners some problems And Fred Swift found that Norton piston tolerances too be too tight in the bore and he had his racing 88 and 650s bore to 0.005 , my Norton Manxman is on standard pistons made by BHB and Honed to 0.003 and these work nice with no smoke or oil loss , to me 0.002 is tight in the bore and 3thou sound be good enough as long as the end gaps are right on the piston rings and do not forget to measure the lands gap as well .I have a document on Piston and Rings and there measurements , I will send a copy to MW for the roadholder and then you can keep this copy in your files for the future uses , yours anna j Dixon
Wassell stocks the "Hepoli…
Wassell stocks the "Hepolite" rings which are made in the USA by Hastings (see: http://www.hastingsmfg.com/ )& are of an excent quality & are offered in .010 incriments from stock to .060 oversize. If you cant find a dealer in the UK, PM me & as a Wassell dealer myself, I can get them for you also (I am in the USA).
Previously eugene_brolund…
Interesting, I'll remember that. There's a Wassell dealer locally.
Incidentally, are Hepolite oil control rings one-piece or three-piece?
Well, I did it my way and…
Well, I did it my way and put it back together, and it's cured the left cylinder smoking issue. Success!
But now the right cylinder's smoking worse than the left one used to!
I don't know what's going on. But I've only ridden 20 miles so I'll try it a bit longer and see if it improves. Otherwise all I can think of is to tear it down again and re-hone the right cylinder, or stop messing about and have a rebore.
A few facts to follow up on some previous replies:
Oil pressure, taken from the plug on the rear of the timing cover: 80-90 psi cold. 30-40 psi hot, 20 psi idling.
Valve guides replaced in February, inlet guides Commando type with seals. Inlet rocker shafts changed to plain type. Valve stems max. wear 0.0005", within acceptable limits according to manual.
Fuel: Murco Super. This particular batch seems to be ethanol-free according to a water extraction test, but their technical man tells me they're being forced against their will to change their plant to add ethanol to all their petrol. He's been inundated with enquiries about ethanol from classic car, bike and lawn mower owners.
Compression test: 12 bar/175 psi both sides. Warm engine, without oil squirted down the plug holes, which would give a higher reading still. Healthy enough?
hello why have you got pain rocker shaft spindles have you fitted the 6 start oil pump, as you have not said, and if you have that amount of compression
then its not the bore, the oil coming for some were else like at the back of you valve guides , have you clean the oil ways in the cylinder head and at the back of the barrel in to the timing chest , these get blocked up and can mimic a oiling problem as all the oil ends up round the top of the valve guides and down the pushrod tunnels
yours anna j
Previously anna jeannette…
yours anna j
It's still got the original 3-start oil pump. I fitted plain inlet spindles when the smoking first appeared, in order to limit the amount of oil in this area, inlet guide seals for the same reason, in case this was the source of the oil causing the smoking. There still seems to be plenty of oil getting into in the inlet rocker box though. I did check the rocker box and barrel drain. Valve guides were replaced by an engineering shop as I wanted them to re-cut the seats afterwards, and they said they were a good fit in the head.
After 75 miles of riding the smoke from the right exhaust seems to be reducing and the plug isn't wet and oily any more, so maybe it's just that the oil rings are bedding in a bit slower than the compression rings.
Hepolite pistons and rings are after market products and are not the originals pistons and rings,
yours anna j
After 75 miles of riding the smoke from the right exhaust seems to be reducing and the plug isn't wet and oily any more, so maybe it's just that the oil rings are bedding in a bit slower than the compression rings.Now you say it well you need the scrolled spindles in and Clean OUT the oil ways from the inlet valve side near were the spring fits and check all the oil ways down from there too the time side were it come out , the is a dog leg oil way in the crankcase like a L shape this gets blocked ,so then if this is blocked the oil ends up running down the valve stem as there are on rubber valve stem seals on Dominator's
Maybe just maybe your cran…
Maybe just maybe your crancase mouth is not parralel to your crankshaft. I have never found a 750 Atlas, Commando or G15 with the cases paralel with the shaft. The worst ones were 15 thou out left to right at the barrel flange. The engine would barely turn over with no rings once I tightened down the barrel. The cases were not mismatched. One set had never been apart. It's easy to check with the top off the engine, all you need is a piece of precision ground bar to go through the little ends and a set of feeler guages. Worth a try!
Bill
Previously bill_moline wro…
Bill
Thanks Bill, as you say, worth a try, and I already have the bar to go through the little ends as I mentioned before when I thought it might have a bent conrod.
I thought this thread had gone cold so I didn't get back to report that the smoking from the right cylinder didn't improve. Maybe I didn't glaze bust it vigorously enough to bed in the new rings, whereas the left side maybe bedded in better because I was concentrating more on it. I'm thinking of having one more go with the glaze buster in the right pot and if that doesn't work it's back to 500cc I'm afraid.
Bill
The barrel is now off again and I've taken it and the pistons to an engineer for diagnosis and checking the bores with a comparator (I think he called it).
With a tight bar through the little ends I've got 15 or 16 thou under the bar at the timing side when the drive side is touching the crankcase mouth.
