Atlas tank/Jubilee tank
Can anyone tell me if these tanks are the same? They look similar but is that as far as it goes?
Andy
Hello there,
As you say they look alike but I am pretty sure that the Atlas/Dominator tank is bigger. I have a Jubilee tank here on my bench so I can give you measurements if this helps. The badges also look alike but again I am sure that the Jubilee badge is smaller.
Patrick
Hello there,
Patrick
Thanks Patrick. Could you give me the dimensions? That would be a great help. Any chance of a photo of the underside? The reason I ask is that there is a Jubilee tank on the NOC site for sale. It looks nice and may be cheaper than having my Atlas tank restored.
Thanks again, Andy
Jubilee badges are diferent in shape and fixing points, I can't imagine that it would be cost effective to modify a tank to fit a featherbed. Just to confuse the issue however,I have a photo of a pre-production slimline tank on a featherbed at the factory fitted with what appears to be Jubilee tank badges!!.
I have a Jubilee and a 99 DeLuxe and the Dommy tank is much larger than that on the Jubilee, if that helps.
hi Andy,
Here are some pictures of a Jubilee tank. The measurements are 485mm from front to rear excluding the rear mounting bracket. At it's widest point it measures 292mm. Measurements taken at the bottom of the tank. The Jubilee handbook gives capacity as 3 gallons (13.7 litres) approx.
Patrick
p4090011-jpg
And just for good measuire here's one from the top. I am in the process of repainting this - that's why it's (almost) down to bare metal.
Patrick
p4090009-jpg
Hello there,
Patrick
this is a jubilee tank and these will not fit a featherbed slimline frame
