I am getting an oil film on the bottom 3 fins of my 650SS Cylinder Head. It is on the rear of the Head and spreads right across the back but does not spread along the sides. I have investigated the usual causes such as Rocker Cover/Rocker shaft end plates etc and now suspect a porous Head.
Does anybody produce a pourable or sprayable sealant that I could run between the fins to seal it off?
Cheers. Mick.
P.S. Is there anyway to do a "search" of the Message board to see if a question has been asked before?
Quite a lot of Dommie head…
Quite a lot of Dommie heads leak through the casting near the oil return from the inlet rocker area. I have even seen a head where the metal has completely fragmented, in this region, between the fins and left a most unwelcome hole.
JB Weld was used ,in this case ,to plug the hole but the patch was a bit unsightly. However, it did the trick. A good degreasing before application is vital.
Plan B which worked on another head, that was porous, was the use of Araldite smeared over the metal after the area had been heated. The heat seemed to thin the glue which then diappeared into the pores of the metal. Afterwards, the head was left for 24 hours for the glue to harden.
Result!!!
The technique of vacuum im…
The technique of vacuum impregnation is used commonly with aluminium castings. A lot of the time this is a belt and braces operation used on new castings when it is essential that there are no small blowholes or porous areas. The part is scrupulously cleaned, dried, subjected to immersion in a methacrylate resin under vacuum and then cured at a temperature that is not going to hurt a cylinder head. This will not plug holes on the macro scale as described above by Phil but will overcome porosity.
There are quite a few companies out there offering this sort of service and I was able easily to find one not too far away. Prior to treatment, I had solvent de-oiled the head in the workshop, waited until I was the only one in the house and then boiled it in a strong detergent solution for a couple of hours. I then ensured dryness throughout by using a final rinse in boiling water followed by a spell in the airing cupboard.
The company declared the head clean enough to proceed without further cleaning although they would have done it for £20 + VAT. The head was then impregnated for a further £35 + VAT.
Unfortunately, I have not yet run it up to see if the technique works but I will be reporting back when I do.
Previously michael_pond wr…
This web site has a section enitlted Help. Item 10 covers the very powerful search function that is available.
Webmaster
I had the same problem wit…
I had the same problem with an 850 Commando, after building it from boxes of bits, & spending a small fortune, oil literally poured from the head & would be dripping off the front of the head after about 10 miles, there was no way the bike could have been used like this, oil would blow back down the sides of the bike & all over my legs, but I really didnât want to have to tear it all apart again without getting at least a few miles on it. I looked at all the options I could find, but they all meant removing the head to do a half reasonable job. Clutching at straws, I decided to incorporate a mod I had installed on my roadster years ago, & added a breather outlet to the inlet rocker cover, teeâd into the original breather going to the oil tank. My hope was that it would stem the flow a bit so I could at least get some miles under itâs wheels, then pull it apart over the winter & sort it properly. To my surprise, the leak dried to the point where I just had a weep that dried off as quickly as it escaped, so all I had was a bit of staining. That was four years & about 5000 miles ago, & Iâm still running it like that. It seems to have sealed itâs self completely now, as I have washed the stains off & they havenât returned. Simply releasing the pressure from the head stopped it forcing the oil out & I guess carbon deposits or similar have now plugged the porosity. Iâm not going to remove the breather mod to find out, but I sometimes wonder if it would be ok now without it.
Regards, Tim
I have contemplated using…
I have contemplated using the dishwasher for this (the mechanical one not me) but haven't mustered up the courage to try it yet. I reckon the detergent will degrease and the heat will dry the casting nicely. Life expectancy (mine) afterwards is another matter though.
Remember that most powder…
Remember that most powder based detergents are to one degree or another alkaline. Most will be formulated to prevent significant attack on aluminium but especially at elevated temperatures I would be very cautious.
By detergent in my post above, I more specifically meant anionic/non-ionic detergent such as washing up liquid which has a near neutral pH. It is a fact that for domestic use, foam = good so these household produsts are put together to foam everywhere. It is also held by the marketeers that thick = good, so many manufacturers increase the viscosity of their washing up liquid with around 1% salt. Yes, good old sodium chloride, again well known for chewing holes in vehicles, so rinse well afterwards.
Previously david_evans wro…
I cleaned a barrel and head in the dishwasher a few months ago. It stunk, and I had to run another three cycles using a whole bottle of rinse aid before it was back to normal. Thank heavens my wife works nights...
best thing for cleaning cy…
best thing for cleaning cylinder heads is a mild acid like Rhubarb deuce and to find cracks or porous metal use engineers blue. its can be thinned down with white spirit , and you can use engineers blue to see if the cylinder head is warped and its as its uses when fitting valves and lapping in valves that if any of you know what engineers blue is, your anna j
Anna, I have a suspicion t…
Anna, I have a suspicion that most people on the forum know what engineer's blue is, in much the same way as most people know what a Manxman is. Incidentally, many if not most dentists use engineer's blue to check bite clearances when a tooth has been filled or capped.
P.S. Don't use caustic soda to clean your cylinder head. An aquaintance of mine did (as a lad) and found he was left with valve guides and valve seat inserts the next morning. 'Twas only a Tiger Cub but even so...
Previously Gordon Johnston…
well I my suspicion that members of this club ,Have little to no idea what a Norton manxman 650 . even is,, some have never even seen one. there one of Norton rare gems as there are only 12 in this country and most of them are not on the road but hidden in a museum or some one private collection .and there is not that many in the USA ether you can say there as rare as hens teeth , but engineers blue you can get this on ebay tools or garage equipment !!!! yoursAnna, I have a suspicion that most people on the forum know what engineer's blue is, in much the same way as most people know what a Manxman is. Incidentally, many if not most dentists use engineer's blue to check bite clearances when a tooth has been filled or capped.
P.S. Don't use caustic soda to clean your cylinder head. An acquaintance of mine did (as a lad) and found he was left with valve guides and valve seat inserts the next morning. 'Twas only a Tiger Cub but even so...
anna j
Of course we all know what…
Of course we all know whatengineer's blue is. It's the colour my fingers go when working outside on a Norton in cold winter weather.
It's also the colour that the air goes when engineers skin their knuckles or find a bit on the floor that should be inside a rebuilt motor.
It's also probably the correct name for the colour used on the first Manxman Nortons.
I bet there are lots of other variations around. Suggestions welcome?
Varicose vein blue?
Varicose vein blue?
Thanks for all the suggest…
Thanks for all the suggestions. I fancy trying the Locktite as an insitu method followed by Araldite if that is not successful. If necessary I am happy to spend the time removing the Head for the Vacuum Impregnation.
Cheers. Mick.
Another thing to watch out…
Another thing to watch out for when using the dishwasher for cleaning parts is that most of them use salt in the cleaning process which (certainly in ours) turns some aluminium parts black; and they look far worse when they come out to when they went in.
Previously phil_hannam wro…
Norton Manxmans are in Metallic pacific Blue , and engineers blue is not a metallic and its a darker blue , dose your hands Phil go metallic in the cold weather, I will not even think about working in the cold, with engineers blue thinned down and run round inside the cylinder head you find where you have a porous patch then you can clean things up a treat it,
Clean all the old oil off (I find brushing it off with white spirit best because it leaves no residue). Warm the head with a hot air blower and then brush all round the suspect area with locktite 290. It is a penetrating locktite and is also used for sealing porous castings. Because the air flow moves the oil around in some strange ways don't rule out the usual place for porositywhich is thepush rod tubes at the front of the head.
It worked for me and was recommended to me by 2 highly respected NortonINOA members, both excellentengineers in the USA (Jim Comstock and Alan Goldwater) both of whom hadprevious successes with it.
