1950 Norton Dominator Model 7 front forks
Will any other model forks fit my 1950 model 7? My tubes are rusted solid in lower legs. I can use the Model 7 triple tree and just put out new forks. Thought itmight be easier to find another set. ES2 or Atlas maybe? Any help great appreciated.
The Model 7 basically used the 50s ES2 frame and running gear. I believe that you should be able to use the stanchions and boots from any of the Long Roadholder Fork models such as model 77 or some of the other singles.
Attachment shows 1948/9 Model 7 front forks.
