Proper 1961 Dominator 99 standard head
I bought a '61 Dominator 99 a while back, and the previous owner said that it has a 59 head on it. I have done some reading and research on finding the proper one, and recently came across and purchased a 22707 (upside down Y) casting number head. It has the 20 degree splay across the exhaust ports, the twin vertical inlet ports with C-C of 1.625 inches between holes. Are there any other key features I should have paid attention to? Will it fit on 22709 cylinder barrels that are on the bike now? Or do I now have 2 incorrect heads?
If the 59 head was smooth alloy above the plugs/between rocker plates then itts the wrong head. If the new head has the milled off ribbing at that place its the right one.Even if you had an SS head that fits I would count it as right enough!.
The 1961 head was fitted to 88/99's from some point in 1959 onwards .It had bigger valves ,ports and raised the compression by about 1 .It should match the barrel .Don't know if the pipe angle changed.
Peter......For reasons that only the Norton factory can answer there were 2 versions of the 22707 head about in 1961. A version for the Standard 1960/61 88 and 99 models plus the new SS head for the 650 bikes which had just arrived. They are all interchangeable within the 500cc, 600cc and 650cc range of bikes except in the areas of exhausts, carburettor mountings, valve springs and to some extent pushrods. The SS head had very widely splayed exhausts at an included angle of about 80*. This often catches people out when restoring a bike.
The 22707 cylinder head that you decribe appears to be correct for your bike. Attached pictures should confirm. The suffix letter was just to indicate which casting mould the head was produced in. The valves are the same size as on the SS head but need the older, thinner and longer 2" springs of the early heads.
The chunks of any Norton Twin cylinder head that need careful checking are any threaded holes. Foremost beingthe exhausts ports and plug holes. Don't forget the 3 underside 3/8" head mounting studs. Next look at the valve seats in case they are badly worn and recessed. Also, in this region, check for cracking between the plug hole and valve seats.
1960%2099%20Standard
Thank you for the additional material Phil, I just received the head this week in the mail, and plan to give it a good inspection over the weekend and make some comparisons to the photos you sent. In the parts book I've been referencing, I noticed several parts differences between the 650SS and the 88/99's - thanks for pointing out the valve springs.Attachments
image-jpg
Well the first Down draft head was Not fitted to the 650SS , Nor was the Cam and Its valve train , or the Barrels and Crank and Crankcases,
The First 650 Machine built out of Bracebridge street workshop , from the 7th of November 1960, was the 650twin Know has The Norton Manxman for Export Only, the Birtish got a revamped models 88/99 in Sport mode, from April 1961, knowen has the the 88 and 99 Sports Speicals ,then to the end of 1961 the British public got too see the 650SS in Blue, at First, and then in Norton Standard colours Black and Silvers so it cost less to compete with the Triumph 650 twins Yours Anna J
Hello again,
Thank you both for the reference pictures. The head I purchased matches more closely to the 1960 std. photos, in that the inlet port manifold mounting holes run in the vertical direction. The other photos have them in the horizontal ( as they were eventually) on the Atlas etc. Also, looking at the Bacon book - the down draft inlet angle appears much steeper into the head, and do those ports run vertically or horizontal? Lastly, this Model 99 was originally sold in London (so wasn't necessarily built for export) and left the factory near the end of April of 1961. This seems to be a time of factory changes and is probably another reason there may be the questions. I have the bike's matching engine & frame S/N's, so would it be worth an inquiry for the factory records? Would they be likely to give any clue as to the original head that was sent out with it?
Peter, the head you illustrated looks exactly correct for your 99. I would not expect it to be fitted with the SS downdraught head - the one with the horizontal inlet studs and splayed exhausts.
Gordon.
