Dear All,
Might need to change my rear shock on the Atlas,
what do you suggest to do?
Option one:
Disassemble the unit check for damping and changing the springs? Where to buy the springs? Wich rate? Wich is the original rate?
Option two:
Change the unit with an Hagon couple, do they worth the cost?
Otherwise, all the other reproductions are made by the same factory in Taiwan and distributed by different suppliers or there are different factories and different suppliers?
Who would be the best?
Paul Goff RGM Classic Bike Shop
In this past post I have found some info I am looking for:
Thanks for any extra tip!
Best,
Edmondo
Rome,
Italy
Try EAW , I found that the…
I tried NJB shocks but the…
I tried NJB shocks but they were too long and had the wrong bushes. I returned them and bought Hagon shocks instead. They might cost more but with shocks you get what you pay for. Do you want to trust your life to cheap and possibly inferior suspension?
I also found that the NJB…
I also found that the NJB shocks were too long, causing the top run of the rear chain to grind on the swinging arm. Plus ....... the shocks were labelled for a Slimline bike but had Wideline bushes. When I returned them for a refund, the seller informed me that NJB made their Slimline shocks 0.5" longer because market research had led them to the conclusion that all Slimline customers wanted their replacement shocks to be longer.
Previously edmondo_perrone…
Previously edmondo_perrone wrote:
Dear All,
Option one:
Option two:
Best,
Edmondo
Rome,
Italy
Well I would use RGM Motors as they post world wide and there fast and efficent and have a good products and the right type of shockers for the Atlas
yours Anna J
Try EAW, I found that their Slimline rearshocks were well made and reasonably priced. As a bonus they came with a range of bushes to suit variations in the bolt holes of  different swinging arms.
