Mirrors wtb for a 1971 LR Fastback
Hello,
I've got a 1971 LR Fastback and I'm looking (without much success so far) for mirrors for it. Not wanting the bar end versions - looking for the type which I think attach to the Lucas switchgear/lever castings.
Can anyone point me in the right direction please?
Alan
You can get the correct mirrors for screwing into the left and right switch consoles from Andover Norton. I fitted pairsof these mirrorsonto my Mk 1A 850 and Mk 3 850 without problem - they screw straight into the Lucas switches.
The only thing you need to check is the angleon the arm - there are at least two different angle options available depending on how high or low you want the mirror positioned.
Small correction to above reply - the left hand mirror in fact screws into the threaded hole on the clutch lever body. It's only the right side switch consolethat has the mirror fitting.
