Fastback...a lucky escape
Well, I've just had a lucky escape. I bought my 1971 LR Fastback a few months age and planned just to get it MOT'd in April and ride it. 4 weeks ago I had the opportunity to have the tank, seat and side panels sprayed, which they badly needed so thought I would do that and give the rest of the bike a general tidy/polish and service. And it needed it as the bike was "tired."
So far so good. I've reassembled the engine parts, carried ot a 12k service and plished all of the alloy etc. This afternoon I took the front wheel out so I could polish the TLS and hub.
When taking the spindle clamping bolt out from the n/s fork leg, the bottom part of the fork leg fell off! It has been completely cracked and the bolt was all that held it in place. God only knows what would have happened if the spindle had come away when I was riding it.
Question now is...has anyone got a near side fork leg they can sell me so I can get the Fastback back on the road?
they do come up on ebay now and then,its not unusual to find a break at this point as people overtighten them,also i had to remove my fastback tank as it was melting with the crap petrol we get these days so look out for that one aswell!,,,,,,,,,regards nick
Cheers Nick - fortunately mines is the Long Range version so its got a metal tank. Didnt know about the cracking problem though and I'm thinking about a pinning and welding job if one doesnt turn up. But that would be the second choice...Alan
I've speculated on the consequences. The wheel is retained by being bolted in on the other side by the nut... the clamp stops the forks from moving sideways away from each other. That would be a big problem for a sidecar outfit but - maybe - not so very serious for a solo.
My bike came with stainless steel spindle. One day I realised that the clamp was not really clamping the shiny metal at all - I could move the fork leg sideways on the spindle with my hand - so I replaced the spindle in the belief that the s/s one was too small. In fact when I measured then they were indistinguishable in size. But anyway - the clamp had never been effective anyway.
Not that I'm suggesting riding with it broken..but probably don't lose sleep over the risk. Probably/possibly etc. etc.
Thanks David - the clamp area has fractured and the circular part at the outside where the spindle goes through the leg is whole. That part doesnt look too substantial - I'll take a couple of photos tomorrow nd post them up. If its a common problem there may be a common fix?
Could be wrong but I think the pinch bolt sliders are readily available new. I bought one pair of sliders from Mick and Angela Hemmings last August, albeit for a Mk3. I know there is an obvious difference with the brake side but the pinch bolt side may be the same part number.
There is a tendency to over tighten the pinch bolt, It only needs to be tight enough to stop the bottom of the fork leg moving sideways. The drum brake sliders are round in section and the later disc brake sliders are oval. At my recent MOT, the tester noticed my headstock nut was loose, (good spot) but missed the pinch bolt. Makes me wonder what else I missed on my rebuild.
Pinch bolt side fork sliders are often broken because people overtighten the pinch bolt. I replace broken ones rather than try to weld them as they tend to crack easily near the weld.
Two versions are now available as Andover Norton Genuine Spare Part: Commando under part# 06-3318 (UNF/UNC threads, oval section) and 03-0031 Dommi/ES2 (CEI/WW threads, round section).
Certainly the lower stanchions were available a couple of years ago. I had this problem with my '71 Commando, and was quoted, then, £60 for a stanchion, or, approx £30 for repair by alloy welding. The welding job was completed in situ, and took less than a day. The finished repair was invisible.
Try Andover Norton
I bought one for my bike from them last year and it was half the pricequoted byother dealers.
Similar items on eBay were only fractionally cheaper but possibly worn out internally. Dont take a chance.......buy new!!!
Big coincidence. My Commando is a December 1971 LR. Is there a pattern arising here?
Thanks for all of the replies - appreciated. The new ones are way out of my league price wise unfortunately or that's the way I would go. A used one would be ideal but a repair may be on the cards if the preferred option runs aground! I've attached a couple of photos to show the breakage.
I really would squeeze the piggy bank and buy a new replacement. That's a heck of a tricky alloy weld and don't forget it's your neck on the line. You have been warned!
By the time the welding preparation, welding, crack testing and machining is completed I reckon the new slider may be the cheaper option. As Gordon says it's your neck plus the innocent party you crash into if/when the weld breaks. Let me know your planned route when out on the bike so I can avoid the area! I would definitely save up for a new slider.
Alan,
Would you post a picture of the whole slider, clearly showing the top and mudguard stay mountings.
I had mine welded when it broke. The job was done by a specialist alloy welder in a factory where they madecomponentsfor fighter aircraft. The welder was very confident that the weld would hold. AFAIK it has held for the last 10,000 miles. I dread to think of the true rate for the job. I suspect a new replacement from Andover Norton would be cheaper.
Alan,
Chris - here's the photos.
Alan
Hi, looks a dodgy casting to start with. Notice the granulation. I have seen Norvil selling a cracked leg on eBay for £200. Gets your money back towards a new one. I have just bought a complete set of Disc forks on eBay in the States for £160, with yokes. If you repair it, then weld reinforcing gussets to it, otherwise scrap it. Best regards, Paul.
One serious argument in favour of buying a new one is this. If we don't buy new spares, the suppliers will stop manufacturing them and produce something else - lawnmowers parts for instance - or go out of business. It's in our own interests to support the spares suppliers who help us keep our bikes on the road. Only if something badly damaged is otherwise unobtainable should we attempt a tricky repair.
On reflection its looking like new if I can't get my hands on a used one. So damn expensive!
Hi, once you've repaired / replaced your fork leg - a suggestion I saw years ago, and have used succesfully ever since, is to put a washer in the gap at the bottom of the fork leg where the pinch bolt goes through the leg and through the washer. This will allow the bolt to pinch onto the spindle but stops the pinch bolt over tightening because it can'tcompletely close the gap, hence stopping the alloy bracket breaking. Being known as a gorilla when tightening bolts this fix has stopped me from breaking any pinch bolt legoveralmost 40 years Nortoning.
Also apologies if I may be teaching grandma to suck eggs but as your original commentseems imply that you are new to Nortons I willremind youto pump your forks up and down a few times before you tighten the pinch bolt so that the forks are straight and parallel and go up and down uninheaded.
Hi Bob,
Thanks for your reply - yes I'm new to Nortons but have had many and various old brits and italians over the past umpty ump years. Good idea about the washer...combined with an earlier one reclamping the spindle in place without the wheel then masuring the gap and making up a spacer/washer to suit the gapmay be the best of both ideas.
Still need to save for a new leg first though... :(
I had a fork leg repaired like this and chucked itinto my naff parts binafter less than 30 miles of use. The two studs could not cope with the stresses generated by the front suspension and the end cap kept coming loose. I would be happy to give it away if I did not think it would end up killing someone.
Thepinch bolt side fork legis available from Andover Norton today. £148 plus the usual additional costs.
NORTON 750 - 1971Item:FORK SLIDER (PINCH BOLT SIDE)Part Number:063318Price:£148.00NORTON 750 - 1971Item:FORK SLIDER (PINCH BOLT SIDE)Part Number:063318Price:£148.00NORTON 750 - 1971Item:FORK SLIDER (PINCH BOLT SIDE)Part Number:063318Price:£148.00
Well discretion (and various pieces of advise) overcame valour and I've got a new one from Norton Race Spares. Rebuilt the front end yesterday afternoon/evening and all looks well. Now I just need to drain the oil out of the crankcase and fill the forks/oil tank/chaincase and oil tank with oil and she should be good to go for an MOT.
Looking forward to many miles of trouble free riding this year. Weahter permitting!
