Hello again. I've been investigating the reason for my wet sumping.
I've pulled off the timing cover. I assume the plunger and spring actually sit in the timing cover and act against the small circular rubber seal which is sat on the oil pump. Am I correct? If so there is no sign of the spring and plunger anywhere. It looks like I've found the reason for the wet sumping. Hopefully you can see the image I've included.
Chris
They often stick in the ho…
Previously richard_payne w…
Previously richard_payne wrote:
They often stick in the housing, especially if the oil is a bit old and sticky - DON'T try to fit one without verifying that the original is not present.
Try measuring the depth of the smaller gallery next to the crank feed. It should read about 0.8" deep.
If yours is there and stuck, a tap on a wooden block might free it, otherwise turn it upside down and lightly play a blow torch over the bulge on the case. As the oil thins, the spring normally pushes the plunger out. If it's really stuck then you might have to resort to drilling it and forcing a self-tapper in to aid extraction but this will mean replacing the plunger.
Thanks Richard. I'm 99.9% sure it's not there and an earlier rough measurement of the depth of the housing would equate with the 0.8" you describe. I've ordered a new plunger,spring, seal and gasket but I will double and triple check that the old one is not lurking in the cover before I fit the new one.
Out of interest, when I bought the bike the seller started it up. It started easily and appeared to run well. It's only since I've got it home and given it a close inspection that I've found evidence that the engine has been re-assembled without too much attention to detail. Head not torqued down properly, loose sump filter housing, re-used crush washers etc. Sufficient for me to realise that I'm going to have to strip and rebuild just for peace of mind.
Regards - Chris
If the re-used crush washe…
If the re-used crush washers you refer to are the exhaust pipe to head seals, I would refit the "crushed" ones. New ones will need continuous retightening until they too are fully crushed. Inbetween times your pipes will be losening off and this is the thing to aviod when running a Commando as it damages the head threads.
Previously david_evans wro…
Mmmmm. That's one area I haven't inspected closely.
Specifically I found a fibre washer on the sump drain plug instead of copper. The sump filter (1.5" nut) was hand tight with a normal copper washer instead of the crush type. The large oil-tank union had copper washers instead of alloy. I expected a small amount of oil leakage but these faults combined with the wet sumping meant that it was leaking oil all over the place. Oh, and the rear master cylinder is leaking brake fluid. It's just as well that I enjoy a challenge.
Chris
hi Chris Am rebuilding my…
hi Chris
Am rebuilding my mk2a 850 an fittednew oil tank banjo alloy washers an the one between the bolt head and the banjo leak no mater how much force was applied (lots more than you should have to)
Copper is mush better for sealing washers but on the ACCESS NORTON Website (google it they have many helpfull threads) there are people who say copper washers also leak on their bikes.
i fitted two Dowty type washers to my tank an that stopped it leaking without have to pull the thing over tightening the bolt! If you have not seen a Dowty seal its a metal washer with a rubber type seal in the bore that seals the faces as the washer is trapped between the bolt and banjo fitting. They are use in high pressure hydraulic systems so will have no problem with oil system on a Norton.
I can not tell you the size or make of the ones I fitted as I just went to a local hydraulic fitting company showed them the parts the man gave me two an said I could have them as they are only pence and not worth the paper work.
Have fun Karl
Looks like Norton anti-wet…
Looks like Norton anti-wet sumpingdevice wasomitted by whoever last rebuilt engine. As already pointed out , check first it's not stuck inside housing with spring compressed which is a common problem (and was on mine when I stripped engine). I'd strongly recommend just forgetting this not very effective Norton designed anti-draindevice and fit a Mick Hemmings valve which is a simple job fitting in the outgoing oil pipe from the oil tank and which really does work properly.
Thanks again for the usefu…
Thanks again for the useful pointers and info.
Chris
If I were to delete the va…
If I were to delete the valve and continue using the Mk3 timing cover, I think that I'd want to block the bleed drilling from the rear of the plunger. Otherwise, a certain amount of the oil pump's output will be sprayed inside the timing cover rather than directed to the big ends. It may not be significant but I wouldn't want to be the one to find out.
As I've already ordered t…
As I've already ordered the spares I'm going to try the original setup. If this proves to be unreliable I can reconsider at that time.
Chris
I reckon that if you ensur…
I reckon that if you ensure the housing has no burrs and polish the plunger so it's an easy sliding fit, you shouldn't have a problem and it will work more often than not.
The good thing with this system is that the valve is pushed open by pressure, rather than relying on suction drawing a valve off its seat.
Thanks Richard I do not ha…
Thanks Richard
I do not have the timing-cover oil-seal tool. Is there a cheap and cheerful way of replacing the cover without the tool and without damaging the seal?
Chris
I've never done it withou…
I've never done it without the tool and most camshafts have a fairly sharp edge. The 'tool' doesn't have to screw in (although that's easiest). It would probably be possible to fashion something out of a piece of wooden dowel. It just needs to gently open the seal as the case is pressed home.
Hi Chris you can fashion a…
Hi Chris
you can fashion a thin plastic sleeve from an old tizer bottle, just cut yourself a section of the bottle 2 by 3 inches, roll the plastic so you have a tube lets say half inch diameter by 3 inches long ,poke this through the new camshaft oil seal which is already fitted to the timing cover , you can use the plastic tube to locate over the sharp camshaft edge and protect the seal from snagging when you re-fit the cover,once the covers home you simply slide the plastic out.
I've also used this method ,but on a larger scale ie thicker plastic shimming to set the rotor/alternator clearance
steve
Thanks Steve. I'll give i…
Thanks Steve. I'll give it a try.
Richard - thanks for your suggestion. I've been thinking about spinning something up on the lathe but I'm basically lazy so if it becomes really necessary I'll probably just buy the tool.
Chris
A small update. I replaced…
A small update. I replaced the anti wet sumping valve and refitted the timing cover using a piece of rolled up plastic milk bottle as a guide so thanks to Steve for that.
I also fitted two 3/4" BSP dowty washers either side of the oil tank union in place of the alloy washers. Result no leaks. So thanks to Karl for that.
The overall result is that the bike has stood for the last couple of weeks without wet sumping and without dripping oil from anywhere.
An oil leak that appears at the bottom edge of the primary chaincase (following the engine running) does not recur when wiped away and the bike left to stand. This suggests that it is not actually leaking from the case outer gasket but from somewhere behind the case. Is this common?
Chris
my primary did the same th…
my primary did the same thing no leaks after filling or when standing for a week or more. But after running the engine a short time a few drops but still not when stood. Then off for the MOT its first time on the road for 30 years an my first time on a right foot gear shift ( boy that eas fun) an oil dropped steady off it but after cleaning no drips when stood.
I check oil tank level that looked same as before then checked primary it had just enough oil to be seen when you remove the level screw. As no part of my garage drive or street is level (sheffeil is all hills and slopes) i my have over filled it an i hvae read that even when filled to the level that is to much an will leak.
i will leave it alone an see if it stops after a short while if you are sure it is not a major leak an would be ok to leave i would do the same if i was you just for a short time to see if as the level drops the leak stops by its self. You can remove the plug that gives a veiw of the primary chain to see if it still has plenty of oil on it for time to time.
Karl
Thanks for your comments K…
Thanks for your comments Karl. I'll keep an eye on it. If it doesn't settle down I'll dig a bit deeper.
Chris
I'd say that the most lik…
I'd say that the most likely source, assuming the chaincase face is sealing properly is from the alternator lead grommet, especially if the lead has been positioned so that any oil splashing onto it can run downhill. The grommets do harden.
Gearchange crossover shaft is another possibility on the Mk3 (but I've never had that one).
Thanks Richard. I'll have…
Thanks Richard. I'll have a look at the areas you suggest.
regards - Chris
