I have had my rebuilt Commando on the road for about 6 months now and with a new frame and isolastics, good tyres and suspension etc. It still tends to weave around too much for my liking at 80 and above. Watching the film on youtube about wobble and weave by Dunlop, it would seem that moving your weight forward as you ride will reduce the weave but that is tedious and uncomfortable. I'm in the process of fitting a cheap steering damper from somwhere in Asia. I'll let you know how it goes.
Just for background, the bike has 18" wheels, AvonRoadriders and a lansdowne fork conversion, Konis on the rear. It's a 1970 Fastback with the early steeper head stock angle. I suppose I weigh about 13.5 stone with my riding gear on.. More pies might be an answer but camping luggage en route to the national rally made only a little difference.
Dave, you need to establis…
Dave,
you need to establish that the swingarm axis is square in two planes to the steering head axis. When the swingarm is angled away from 90 deg to the steering head and there is suspension movement, the rear wheel travels through an arc which constantly changes the degree of alignment between rear wheel and frame centrelines.
It's this that causes many problems with handling. It can be a similar feeling to worn swingarm bearings. The isolastics usually get the blame but the problem is frame geometry.
I've found with 100/90 19 Road Riders on 2.5 inch rims, front and rear, the front needs changing approx. at 3,000 miles to maintain wobble free steering hands off. They then get used at the rear, which can be worn down to the wear limit with only a slight shimmy over white lines - no movement with good tread. Steering damper helps if the front tyres worn past 3,000 and also when the forks bang into mini pot holes in the road when cornering at speed.
Had similar front wheel sh…
Had similar front wheel shimmy problem at certain speeds and rates of accelerationon my Mk 3 when I had it outin Kenya even with new tyres (TT100 4.10 X 19)fittedback and front. Fitted a Norton / Triumphsteering damper which cured everything and made handling rock solid atall speeds / acceleration rates -and only needed the mildest of settings.
After shipping back to UK and a total rebuild bike handled well from the outset without trace ofweave or wobble. Possibly a properly refurbed swinging arm did the trick.
Assuming all bearings new…
Assuming all bearings new tyres etc are good and you've still got handling problems then the frame geometry is out. Steering dampers only mask the problem. Due to production methods/quality control, some bikes are going to be worse than others.
The isolastics are not the cause of weaves and wobbles otherwise how would Peter Williams achieve what he did on the monocoque, which he states was the best handling bike he'd ridden.
I'm happy with the geomet…
I'm happy with the geometry of my frame and with new swinging arm and isolastics and a rose jointed head steady, the handling is good round the bends . It's the 80plus straight line cruise that is the issue. With an alloy tank I'm reluctant to load up a tank bag to bring the C of G forward but I think that's where the answer lies. In the meantime a steering damper will mask the underlying problem but provided it works Hmmmm.
As your bike weaves in a s…
As your bike weaves in a straight line then I can't see how the handling can be good around the bends, especially at 80mph. If centre of gravity is to blame then an Interstate would exhibit the same symptoms as your Fastback, as the riders mass is further back. My Interstate steers and handles fine around corners and even in a straight line.
I don't see how a steering damper is going to alter the machines centre of gravity. Not that I think centre of gravity is the problem, it's the frame geometry. Checking before assembly started is the way to go. If accurate measurements aren't made how do you know?
My Commando has TT100s on, standard 19 inch wheels, and shakes its bars at 30 mph and weaves over white lines at 80 mph.
I've tried tightening the isolastics up, messing about with tyre pressure, but nothing makes much difference.I blame the isolastics- a rear wheel that has sideways movement built into isnt ever going to be very stable, but I'm not a geometry/handling expert.I just accept it as part of the bikes 'character'I'd be interested to here if a steering damper makes much difference.I have always eaten plenty of pies.
