Hi all,
ive recently started to restore a 1975 850 commando and whilst im not a mechanic myself i thought i would give it a go anyway, after generally cleaning up and bolting bits back together ( bike was in a box of bits beforehand), managed to get it to start and to the untrained ear sound pretty resonable. my joy however was shortlived as i noticed oil seeping from the righthand exhaust port and concequently oil blowing through the exhaust pipe and straight up the garage door. although the lefthand side seems to be fine. any suggestions gratefully recieved.
A rebuilt engine will chuc…
I had this problem on my D…
I had this problem on my Dommi with pressure fed rocker spindles, oil came out of exhaust ports
They can push too far into head so the ears on the spindle plate don't hold them the right way round causing flooding of rockerbox
I think there was a thread about this somewhere but can't find it
Worth a check
Rocker spindles incorrectl…
Rocker spindles incorrectly fitted can be a cause of oily engines. Generally however, both cylinders tend to be affected to some extent.
Peter suggests that the problem is confined to one exhaust port.
Thanks for the input guys,…
Thanks for the input guys, i will be checking out your suggestions at the weekend and let you no my findings.
I came across a similar pr…
I came across a similar problem but it turned out to be an inlet stem sealhad poppedoff. It then goes up and down with the valve and acts like a pump!
Also long ago on a domi 99 it turned out to be a loose exhaust valve guide in the head. but unlikely on a Mk3.
A rebuilt engine will chuck out some oil until all the bits have bedded back in. Beyond this you might have worn rings, worn bore or worn valve guides to check out. These engines do tend to eat valve guides. My Commando has two that are loose in the head and consequently leaking huge amounts of black gold.
Drop your right exhaust and have a look in the port. If there is an obvious dribble running down from the guide that could be the problem.
If the whole area is wet with oil then it could be rings, inlet guides or an over-active oil-pump relief valve.
