I'm rebuilding the gearbox in my Mk111 and using a roller bearing on the primary side of the layshaft. I fitted the inner race to the shaft and then I found I had to gently tap the shaft in order to install it into the rollers. Now I'm finding the shaft cannot be removed by manual pulling. I dont think the countershaft and 4th gear are binding. Is this normal?
-Allan
No, did you use loctite to…
Previously allan_branney w…
Previously allan_branney wrote:
Yes a very small amount.
Remove the loctite, if it was used to hold a loose bearing in place then instead you will need to copper plate the OD of the bearing to restore the inference fit in the case. If it was just because you thought it would help but the bearing was not loose then it has had exactly the opposite effect.
Previously john_holmes wro…
Its a new shell. The reason I applied the Loctite is because the Old Brits guide states he always applies to both bearings. It will now require bearing removal.
Well you are not alone in…
Well you are not alone in having this issue and Old Britts are wrong to recommend locitite where its not needed.
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=536162#Post536162
Interesting. Thanks for th…
Interesting. Thanks for this. My next questions is what temp can I heat the cases to in order to reuse the bearing? Initially I had heated the case to 160 deg C. I expect the countershaft gear and layshaft may well be heated also as they are pretty tight in the bearings.
The loctite should release…
The loctite should release at 400F or 200C, as long as the steel does not blue you will be ok but you are not far off that so be very careful as steel blues at 500F or 260C.
My Daughter who is a B. Eng bearings engineer always told me off for heating crankcases above 120C in order to removed main bearings, but what does she know -- where needs must !!!
120C is fine for a bearing…
120C is fine for a bearing sitting in an alloy case without loctite, but the loctite will hang on unitl 200C. So you can do 120C and have a bash with the hammer but the layshaft bearing is in a blind hole so what are you going to bash it with, drill through the back ? and then be left with the problem of sealing the holes.
Lesson to be learnt is to only use Loctite when needed and never on an alloy case with a steel bearing as it does not last anyway as the heat cycling will eventually cause it to lose its grip. In this case the bearing will be destroyed by the wrong running clearance so thats not an option.
Between a rock and a hard place comes to mind and glad I met this problem 25 years ago and found out on my first engine rebuild and its a lesson I have never forgot.
Tried heating the casing t…
Tried heating the casing to 175 deg C and the bearing has not moved. Also tried local heat with a blow torch. Looks like im going to have to heat this to 200 deg C as the loctite is clearly stopping it from dropping out.
I'm concerned about re-usingthe bearing after that temp.
Try grinding the rounded h…
Try grinding the rounded head of a small coach bolt so that it is quite slim you may be able to slide it behind the rollers and give a little leverage after applying the heat but if you've gone up to 175 degrees it certainly won't be a good idea to reuse the bearing.
Tempering steel to the ext…
Tempering steel to the extent where hardening is reduced occurs between 540 and 600 degrees C by which time your gearbox case would be getting close to meltdown (650C)
No, did you use loctite to hold the outer in the case ?
