Crank journal stains... rust?
Hi all
I have pulled the rods from my 1968 commando and found strange staining around the oil holes. See pic. It has done 17000 miles and has been off the road since 1990. The shells and like new, no visible wear and the crank and it measures up good. There is no wear on the journal and the marks can't be felt.
Has anyone seen this before? I'm thinking it is corrosion from the acids in the oil while it was sitting. Have given a light polish and the marks don't come off.
I'm thinking it would be ok to use as is with new shells... But would like to know your opinions..
Thanks D
image-jpg
I might be wrong but this looks to me like the shells have picked up on the journal. Oil will acidfy if the engine is not run for some length of time and then stain and/or eat into the crank journal. Generally you get a pitting where this happens.
If you are going to fit new shells then you need to lightly roughen the journal surface to help the bedding in process. Similar to deglazing a barrel when fitting new rings. The good news here being that only a few hundred miles of running in is necessary.
Use a micrometer to check the journals before rebuilding.
dean
please don't roughen up the crankpins as suggested by phil ,the slight pitting you've got on your crankpin will do no harm,as long as it's under the surface (it's basically an extra oil pocket)
use a micrometer to establish that the crankpin is within service limits(ie not oval/tapered or barrel shaped)
If you feel the need to clean the crankpin up, use a very fine grade wet-n-dry and finger pressure or the cloth side of some clapped out emery cloth ribbon soaked in fresh oil.the idea is to remove only the corrosion and NOT any bearing surface area
when you fit the new shells to the crankshaft ,they should be able to drop under there own weight with no tight spots( 25 lbf torque)
steve
I'm with Steve on this one, a gentlelinish with some oiledVERY blunt 1200 grit wet and dry, or fine steel wool, only on the apparent stains, to ensure that the journal is smooth in that area, should be enough to put the crank back in service along with new shells. I definately wouldn't be trying to remove the stains, as they may go several thou deep, which would render the journal unservicable.
My mistake ....poor choice of wording. Polishing is far better then roughening. I generally use fine W&D and worn Emery.
The important point here is to establish what the stain actually is. The photo suggests, to me, a transfer of the big end shell white metal to the crankpin. In which case it must be removed or will chew up new shells very quickly.
Thanks for the input . The marks are not from the shells as they have no marks at all, they look like they were fitted yesterday. Also they condition of the rest of the internals is mint... Even the camshaft is like new and if it had anything in the oil this is the first place it shows due to the high loads.Which brings me back to acids in the oil when it was laid up corroding the surface...
The journal is STD size and I'm pretty sure I'm the first one in here due to the condition of the fasteners, tab washers etc. all this being said the journals measure up at 1.7498 which is 0.0006" below the minimum diameter and as the tolerance for the journal size is only 0.0005" 1.7509-1.7504 I'm concerned the this may be too much wear. All other measurements are good only about 0.0002" ovality. It is only the drive Side that is like this. The timing side is bang on although the stain marks are on both journals.
i hate to be so picky about this, but this is the first motor I've rebuilt with plain bearings and want it to be right. Also I don't want to spend money on work that isn't needed.
thanks again. D
Created with Photo Editor-
It's on STD ? then I'd guess those marks pre-date the shells by quite a margin. They may have come from an even earlier set of shells or from a lay-up period. No one will ever know. Have a measure up with a micrometer and so long as they are not proud of the surroundings you have nothing to worry about. Journals need to be smooth as possible to avoid pick up in low pressure scenarios like start up.
Regards Rob.
If your journals are already below the minimum tollerence, surely while it's appart, it's a perfect oppertunity to have them reground? Undersize shells are no more expensive than std, which I asume you would be replacing anyway, so it's just the additional cost of the regrind. This will take care of all your issues & should ensure you won't have to worry about the bottom end for many years to come.
Regards, Tim
Thanks all for your input.
i have decided to go ahead and get the crank ground. I have seen a local company that say they can carry out the work. I live in Abu Dhabi in the UAE and don't think I will trust these guys. So my issue now is to get my crank to someone trustworthy.
Can anyone recommend someone. I'm thinking of sending it to SRM as I have dealt with them in the past and found them excellent. Any other recommendations?
BTW nice day here.... 9:45 am and still only 28 deg C. High of 38 tomorrow!!
