I have a trashed Mk3 Boyer fitted tyo my 1974 850, R/Holder has recently run an article on electronic Ignitions butfrom your experience which system should I replace the Mk 3 with?
Iwould choose the tri spar…
Previously roger_johnson w…
Please keep us informed on this, I for one will certainly be interested in what you decide upon and the sort of results you get from a new set-up.
Possessing two 850 Command…
Possessing two 850 Commandos, a Mk1A with original points ignition and a Mk3 with Boyer 3 , hate to say this but I prefer the original contact breaker points system. No problem with the Boyer setup but it gives a different engine characteristic - more ponderous and less crisp than properly adjusted contact points. Of course you need to make occasional timing checks and adjustments with points but once you've done this a couple of times it's an easy routine - and there's the advantage of simple home fixing in the event of a problem rather than being faced with possible mysterious electronic faults. You may not have wanted to hear this !
My standard Pazon Surefire…
My standard Pazon Surefire works well. First one failed after 20 mins but was replaced next day. One of the trigger coils went open circuit. No more trouble in 7 years.
Pazon Altair here, starts…
Pazon Altair here, starts easily, idle is very stable. Very happy.
Removed a sort of servicea…
Removed a sort of serviceable older Boyer due to poor starting unless battery was 100%, as current draw unacceptable. Fitted a TriSpark + new twin output coil + NGK Iridium plugs and did nothing else, never looked back. Starts easily, smooth tick-over which the Boyer did not support and receive excellent performance. Also no "Black-Box" to stash away somewhere, but your call!
Good luck!
I don't have any experien…
I don't have any experience with Tri sparks, but there is some evidence that inside a bike engine might not be the best of places to put electronics, however well potted, for the long term health of said components. Inside a Commandos timing chest is a pretty harsh environment.
so I would fit a Modern Boyer(low voltage issues sorted) or a Pazon.
I've had two Trisparks go…
I've had two Trisparks go wrong on my Commando and have just gone back to Boyer micro iv as I know it is generally reliable, and so concur with Charles comments and suspect that this could be the problem but can't be sure. I could not tell any significant improvement between my original Boyer micro 111 and the Trispark but I did like the neat fit all in the points cover. I also didn't like having to go home in a breakdown truck when the first Trispark failed!
Having said this I have a Trispark on my T160 which is a remotely mounted black box type and this is excellent.
Just thought I would add t…
Just thought I would add to the discussion. I recently had some problems with a previously very reliable boyer mk3 unit and reinstalled the points setup. It takes a little time to setup correctly but the bike runs much better with this arrangement than it ever did with the boyer. It revs much better and smoother. So I would be in agreement with James on this one, but does anyone know why it runs better with the points setup?
Iwould choose the tri spark, all the electrics fit in the points cover,easy to fit, and runs a lot smoother. expensive but the best .
