Power Arc advanced electronic ignition
This maybe going over old ground but has anyone fitted this type of ignition, is it worth it, does it improve reliability, give better performance, makes for a cleaner running engine?
Neil Commando 1974 MK2A 850
I have not fitted it but I have seen mixed reviews like Marmite, the main issue seems to be the multiple sparks it gives making strobing impossible so you are relying on the static timing being correct.
