ATF oil which brand
Which brand of ATF is best for my primary chain case Mk3, some ATF oilsare nowsyntheticie shell dexron 3 so presume this is not recommend.
Any recommendations welcome.
Phil
If this is an 850 Mk3 then ATF is not really suitable. It is too thin for the hydraulic primary chain tensioner and the result is a chain that is consistently not tensioned.
I use a mineral 10w40 motor oil and haven't had any problems with clutch slip.
