Commando cylinder head re-conditioning in Devon
Hello NOC
Does anyone know of a motor engineering firm in Devon experienced in 750 Commando cylinder head re-conditioning. My 750's head needs new valve guides and at least one of the studs has pulled the thread in the cylinder head.
Any and all replies appreciated.
Thanks, Andy
Previously Andrew Heathwood wrote:
Hello NOC
Thanks, Andy
Not in Devon but I had my head repaired by Norman white at Thruxton Andover. He did a good job including replacing valve seats, welding up gouges in the head chambers and remachining and replacing exhaust threads.
On Google Dave Massam motorcycles list classic bike repair, you could investgate him.
Hello NOC
Thanks, Andy
Thanks for the reply Christopher
It looks like I'll have to send the cylinder head off to a specialist. That's okay. I'd rather naively thought there might be a more local engineering firm with the skills and experience to do the work.
Andy
Hello NOC
Thanks, Andy
Hello well I could do this job in my sleep , so can you so you do not want a engineer , all you need is a good gas oven and a set of tapes and dies and some lapping past,
Andrew. As Anna said, it is straightforward enough; not needing a Commando specialist. If you don't feel like doing it yourself, any reputable engineering company, particularly specialising in engine rebuilds, can do it. Depends where in Devon you are? I am over the Tamar in Cornwall, and Bunts Engineering at Bridge End Garage, Wadebridge could be entrusted to do the work. They have done various jobs for me over the years, including grinding the crank on my 650SS etc. I am shortly going to take my Commando crank in to them. 01208 813655.
Ian (and Anna)
Thank you for your responses.
I thoroughly enjoy working on (and riding) my Norton Commando but to quote Harry Callahan "A man's got to know his limitations". I'm happy spannering and measuring but when it comes to drilling and cutting precious metal I prefer to handover to an expert. Thank you Ian for the Cornish option which I may go with.
Regards, Andy
Whoever you get to do the job, you may want to do your homework on what guides you wish to use, maybe sourcing them yourself, along with valves, springs, caps, collets and heatproof washers. They can the lap the valves in, and return it to you with valve gear assembled. You may want to wait until the old guides are removed before purchasing the new ones, in case oversize guides are required.
While heating the head and removing guides is simple enough (provided the combustion end is totally free of carbon) its unlikely a simple lapping job will be enough. New guides usually need a small cut first (with a proper cutter) or you will be lapping forever...Oversized guides are a possibility and often needed if they are pressed out cold covered in carbon and ripping up the bores, just a thought.
I'm game to tackle most things (fixing washing machine is current project), but I wouldn't trust myself to do this. I live in Lincolnshire &went toNorman White, he did an excellent job, try & deliver/collect in personyouget the bonus of seeing the projects he has on the go & he is averyinteresting person to talk to.
If you do post make sure you wrapsecurely and put in lots of packing to protect the head. a replacement is not going to be cheap! (might want to insure it also)
Don't know where you are in Devon, but I would trust Dave Massam at Colyton, or Cox and Turner just over the border in Tintinhul in Somerset, recommended by the Norton Doctor himself! They did a good job on my ES2 head and there was at least one other Norton on the bench!
A big thank you to all who responded. For family health reasons it's difficult for me to travel too far from home to get work like this done.
I tried calling a couple of local firms but was not happy from the conversations that they would do a 'proper job'.
So I've gone with sending the cylinder head to BLR Engineering of Wallington who clearly know what they are doing from the telephone conversation and have been previously recommended on this forum.
http://www.nortonownersclub.org/noc-chat/technical4-commando-forum/390530013?b_start=0#85639643
Thank you again,
Andy
