Commando centre stand pivots
The centre stand pivot holes in the gearbox cradle on my Mk3 commando 850 have become very worn. I had them them welded up and re-drilled about 15 years ago. They were never quite in the right position after that. Consequently now I've got the bike stripped down again, I don't have a reference point to enable me to have them welded up and re-drilled in the correct place this time. Does anyone have a drawing showing where the holes should be or able to provide me with measurements from an unworn gearbox cradle which would anable me to ensure the holes are correctly positioned this time?
Hi Robert,
I am a little confused, why are the holes in the gearbox cradle worn ? The only bit that should be worn is the holes in the centre stand.
There should be a pivot bush that is firmly fixed in the gearbox cradle and the centre stand pivots on those bushes.
I am sorry this does not actually answer your question. I will do some digging as I am sure I have seen some drawings somewhere.
Tony,
There is also some wear in the centre stand holes, but Im sure I can deal with that.
I don't know why I have wear in the gearbox cradle holes but my Commando has done a lot of miles, including about 25 years of commuting between Morpeth and Newcastle all year round, so I would guess that road salt corrosion may have lead to the bushes becoming lose in the gearbox cradle and starting to turn when putting the bike on the stand. Once the bushes start to turn the wear is going to be shared between the stand and the gearbox cradle.
Bob
Hello Bob, glad to hear that the old Mk3 is still putting on the miles...the first Commando that I ever recall wearing out the cam bushes too...but hadn't it had done about 100,000 miles by then ?
I don't have an NOS cradle anymore but ought to have one that's only knackered to measure if no-one else comes up with anything better.
It is a fact with well used Commandos that the side to side rocking as they're pulled onto the stand wears the inner face of the stand and the outer flank of the cradle and with the standard 'Staytite' nuts holding everything together, everything enlarges.
I've actually been through more mainstands than camshafts which I think is the sign of a good Commando !
Hello Richard,
Good to hear from you. You've got a good memory. I think it was at about 70,000 miles when the cam bushes went. Now I'm up to something like 260,000 miles, so I suppose my Mk3 is pretty well used (although I'm sure there will be others that have done much more!)
Certainly the outer right hand side of the gearbox cradle has been worn thinner by the stand chafing against it and the washer on the inside of the left hand side has worn that away quite notably. I think its just a consequence of using the bike.
Thanks for the offer to measure up your knackered cradle if no one else comes along with anything better, but lets wait and see if anyone else come up with something better in the next week or so.
Bob
Hi Bob,
i've got a new one (I bought years ago) waiting to go on my similarly high mileage Commando. I've thought about welding / fixing up the original over the years as the wear got worse but decided on replacement ( a job for the Cristmas holidays) I can measure it up if you like, drop me an e mail to discuss. Personally after all these miles I'd go for a new one, your bike deserves it.
Gino,
Thanks for your offer. Having seen the cost of a new gearbox cradle, I'd prefer to repair and reuse my existing cradle.
I'll send you and email once I've spoken to the guy who will do the work.
Bob
I don't know if the MkIII cradle has the holes in the same places as the earlier ones, but I have the measurements for those here as I'm building a 'special' cradle for my hot rod.
The main problem when it comes to mapping out the cradles is that there's so little to reference from - i.e. no convenient datum line. The way I did it was to machine up a dummy isolastic rubber in aluminium - this, along with a set of bolts with centre drill reference marks in the middles, meant I had accurate points to measure from.
I then made up a set of test pieces using the coordinates I'd established and checked that they fitted - then double-checked that they also did so on another cradle.
Anyway - if you let me know if the holes are in the same places I'll dig out the relevant info for you!
Patrick,
thanks for your message. I'm pretty sure the holes must be in the same place on all Commandos whete the centre stand is mounted on the gearbox cradle. I think the only significant differences are that the pre Mk3 models had a slot rather than a hole for the top gearbox mounting bolt and that it also had the cotter pins to locate the swing arm spindle. The latest stand fits all.
If you could send me your measurements that would be much appreciated.
Bob
OK - I've just taken these numbers off my CAD drawing which are based on the measurements I got from my MkIIA and Fastback cradles:
Centre stand hole to bottom gearbox mounting hole (centre to centre) = 1.600â
Centre stand hole to lower front engine mounting hole (centre to centre) = 7.313â
Centre stand hole to swing arm pivot hole (centre to centre) = 6.100â
Centre stand hole to isolastic hole (centre to centre) = 10.254â
Centre stand hole to upper engine mounting hole (centre to centre) = 9.365â
Please note that it's is very hard to be precise when you're measuring a badly worn hole, so I would strongly advise that you double-check these to make sure they match up with your bike!
Patrick,
Thanks for those measurements. I've measured them out on my gearbox cradle and all five arcs cross in the same place. That must be a testament to the accuracy of your measurements.
For the benefit of anyone else who may want to establish the correct position of their centre stand pivot bolt hole in the future I'll destribe how I measured the position on my gearbox cradle (which is of course 3 dimensional unlike your 2 dimensional drawing). Firstly I reduced each of the measuements you provided by half the diameter of the holes you were measuring from. This enabled me to measure from the inner edge of the holes which is much more accurate than trying to guess where the centre is. The only difficulty which then remained was how to measure from the Isolastic mount. For that I measured the height of the Isolastic tube above the plane of the gearbox cradle side plate, and then used Pythagoras' rule to determine the actual distance from inner circumference at the end of the tube to centre of the stand pivot hole.
Thanks once again for your help.
Bob
I'm delighted to hear that I've been able to help! I made my measurements by putting a tiny pock mark in the middle of some appropriate bolts using a centre drill. Those then gave me a reasonably accurate pair of reference points to measure between. You can't, of course, be completely spot-on because of wobble between the bolt and the hole, but by determining the maximum and minimum values - then halving the differences, you can get pretty close. Anyway - I hope the job goes well for you!
