little help please, i have the norvil replacement kit for the rear isolastic ,is it possible to fit this kit without removing the drive train ??sorry 72 roadster 750,i read on some american forum that the eng cradle could be lowered and leave enough room to install from one side the new bonded kit thank you steve
Not with the long bonded i…
Previously david_evans wro…
Previously david_evans wrote:
Not with the long bonded isolastic rubber. The primary drive will have to come off, inner chain case off, gearbox out (cradle needs to be released from the back of the engine to unmask the slot in the RH cradle plate to allow the gearbox to be removed) Cradle and swinging arm can be removed together. About an hours work with the right kit
oh that sounds like a big job ,and some special tools (clutch holder?)about an hour you say ?and no doubt all new seals would be a good idea ,thought that other site was to good to be true !just leave the front iso connected and lwr the whole cradle, gearbox,assy so as to just gain access rh side to push thu
and sorry forgot to say th…
and sorry forgot to say thanks !!!!!anyone with any pics please fwd to camste54@hotmail.com
<!--P { margin-bottom:…
<!--P { margin-bottom: 0.21cm; }-->
The method below is copied from the files section of the INOA List on Yahoo groups, posted there by Mike Taglieri.
I fitted my verniers using this method and it worked a treat.
Subject: Easier Way to Rebuild the Rear IsolasticThe standard workshop manuals for the Commando generally tell you that the rear Isolastic mount can be rebuilt only by removing the engine, or even the entire power train. Today, helping Chuck Contrino rebuild the rear Isolastic on his '72 Interstate. I was finally able to test a procedure I've been contemplating for a long time that lets you rebuild the rear Isolastic without significantly dismantling the rest of the bike. It worked very well, and this is how you do it:1. Remove the tank.2. Remove the primary (optional -- see below).3. Remove the horn (optional -- see below).4. Remove the air filter(s) and the exhaust pipes.5. Put the bike on the centerstand and fasten the centerstand with safety wire, electrical ties, bungee cords, etc., so it cannot possibly collapse. Do not fasten it to any part of the frame, but only to the engine plates or some other part of the bike that hangs on the Isolastic mounts.6. Slightly loosen the nuts on the large central bolt that runs through the rear Isolastic, and also loosen the nuts on the headsteady.7. Put a small hydraulic jack, etc., under the middle of the left frame tube (with padding to protect the frame) and slowly raise the side of the frame until the left foot of the centerstand just leaves the floor. At this point, the weight of the frame does not rest on the central bolt of the rear Isolastic, and you can remove it easily. Using a suitable drift (a 1/2" socket extension works well), tap the big bolt loose, catching the various metal parts of the Isolastic that fall free when it's out. (By the way, using a hydraulic jack this way is also useful for getting the bolt back IN when you're done, and you can look through the hole with a flashlight and move the frame until the parts are exactly aligned).8. Lower the hydraulic jack. Now the frame is hanging on the powertrain by the front and top Isolastics, and the top Isolastics show it by twisting slightly under the weight. Lift the rear wheel (with a 2x4", brick, etc.) until the top Isolastics are no longer twisted. Now, remove the side plates of the top Isolastics. (You do not have to remove the engine steady from the top of the engine).9. The powertrain is now resting on the floor, held up the centerstand, but it's attached to the rest of the bike only by the front Isolastic. Now, put more stuff under the rear wheel to raise the frame until the centerstand almost comes off the floor.10. At this point, the frame tubes are out of the way and the rear Isolastic is completely exposed on both sides for rebuilding.THE "OPTIONAL" STEPS: If you didn't remove the primary, the Isolastic is completely exposed only on the right side, and you will need some kind of hook to pull the rubber parts out. If you didn't remove the horn, the frame tubes will be partly out of the way but not entirely. I recommend taking off both of these items if you're removing the original Isolastic rubber parts, because if they're truly stuck in there, it's a %$#@ of a job to get them out. On the other hand, considering how awful a job it is to remove the horn, you may want to try this first with the horn in place and remove it only as a last resort. (By the way, if you pound on the central rubber with an ordinary drift to get it out, the rubber absorbs the shock of the hammer blows before they get transmitted to the edges. The best way is to pound on the edges of the rubber by using a very large socket on an extension as your drift).REMOVING THE HORN: As anyone knows who has tried it, this is one of the ultimate bastard jobs on the bike. You can do it with the rear wheel in place by unbolting just the front part of the rear fender (two bolts near the top, two nuts on studs near the bottom), and flexing the fender enough to "pop" it off the studs and move it down. These studs turn out to be the bolts that hold the horn mount, which you remove (teaching children in the area several new words in the process). Finally, you can squeeze the horn out of the space between the frame and the fender -- moving the rear axle as far back as you can will help.
Previously iain_brown wrot…
Previously iain_brown wrote:
The method below is copied from the files section of the INOA List on Yahoo groups, posted there by Mike Taglieri. .........
. ....... Finally, you can squeeze the horn out of the space between the frame and the fender -- moving the rear axle as far back as you can will help.
thank you ,isnt there a note somewhere in that info "will not work on bonded isolastic"if im wrong, i very happy and will try this this week thank you
I've just finishing off d…
I've just finishing off doing this job. On my 850 mk11a and fitted RGM iso
I removed the oil tank,air filter,carbs,horn and plate(only removed this to test the horn out)Front iso and top iso
Also the Z plates
. Worked from the right hand side and also used a scissor jack same as Iain did and on the side stand.
The rubber boots i inverted them and just rolled the boot over
Used red rubber grease to lube the tube from both sides this was a must do and excess can be cleaned off.
Can lift the engine to re-align,but need another pair of hands to put the bolt back in
Bit time consuming but i would do it again. Maybe best if the whole cradle is out
Good luck
Previously john_alexander…
Also the Z plates
Good luck
Previously stephen_campbel…
Also the Z plates
Good luck
firstly thxs all for the replies ,two issues, one did all of the above but cannot get enough access to push new bonded norvil into place ,then with a stoke (?) genius read desperation!trying to get more movement i also undid the shocks i think this may be my mistake ?????as the eg cradle seems to have moved slightly rearward as apposed to downward ,secondly removing the old iso parts there are five rubbers on the replacement there are only four (no centre )so is this okey ??i have to come in now as the kids next door are playing in the garden and i dont want to teach them any new words !!ANY help much needed if i just go for it and release the front iso would that save the day??i have the frame supported from the rear hoop with stepladder and ratchet strap again thxs all sorry for being a pain (read stupid )
thank you all for the help…
thank you all for the help did manage to fit rear removed kickstand and had just enough room ,next problem, removed front iso cradle but found under rubber gaitors a vernier !but as i had the kit at hand replaced anyway (to start with both new )but the norvil does not have enough thread to adjust to the required gap not even close could anyone please shed some light on this ,is there different width cradles ??help please
There are 2 different widt…
There are 2 different widths of front cradle, pre MK3 is wider than the MK3. You can convert pre MK3 to MK3 by turning the longer side shorter to match the short side so they are equal in length, its 1/4" wider from memory. Have done it myself but then I have a lathe, you could post it to me if you are in UK.
This may help
http://www.basmotor.se/eng/teknik/norton/n_isolast.html
This was before vernier isos were made longer so suit pre MK3 cradles, so you could get a longer replacement.
Previously john_holmes wro…
This may help
thank you so much, the rears were the older type multi tube with rubbers fitted (think older)but as you say some one had fitted an isolastic (po?)that was adjust able (cant imagine why only the front as the rear is sooo easy !!)the front rubbers look in good shape ,,only the nylon/fibre(?) washers showed signs of wear,but are the same size as the old rears which have no wear marks at all was thinking clean all and reassemble with the washers from rear ??? again thanks all sorry for asking daft stuff !!just had a reply from norville they say i should exchange the kit i have for a different part number again thxs all
John, How did you hold the front mount in the lathe? Did you use a very wide centre and face plate at one end? I have a very similar (but completely unrelated) thing to work on.
Previously Jonathan Soons…
I got the chuck to fit the ID of the main tube on the opposite end I wanted to do the cut eg the short end, then to make sure the cutting forces did not try to push the tube to one side instead of a cutoff cut I cut from the side on the full thickness of the tube and shortened the tube on the long end as the tool moved across. I have a 12" chuck which helps.
If I am using a weak holding method I always go for a cutting action that increases the holding force instead of pushing at 90, if I can't then I can go to a fine feed of 1.5 thou per rev and take a number of cuts with a very sharp tool. Saves on use of faceplates and 4 jaw chucks which weigh too much and too long to set up even though I have them.
