Breakdown.
Used Carole nash recovery last night via Boarhunt well impressedthe guy took good care of the old Gal and was there in 30 mins even stopped to check the straps before the motorway (Highly Recommended).
Previously Neil Wyatt wrote:
What was the problem, Peter?
Hi Neil a new Iridium plug had failed but also when I drained the float bowl the main jet came out with the fuel (my fault nervous of brass threads) thanks for asking Pete.
Hi Pete, the failed plug, making your Commando a single the main issue. I have always used the standard Champion plugs in my Commando (NY7C I think) and never had one fail. A lot of hype about fancy plugs when the originals work just fine.
I did, on another bike have a main jet drop into the float bowl, but it was only over about 40mph there was an issue.
You may have one, but there is a special tool to remove / replace main jets in Mk 1 Amals, without having to remove the awkward float bowl.
thanks for info . On standard plugs now I was running Iridium plugs on advice because of the boyer fitted,
Hi again Pete, My Commando has been running well on Boyer and standard plugs since 1988. The only issues I ever had was when I changed to a single Mk 1 Carb. Took a while to get that right but eventually got there. But nothing to do with the plugs!
Hi Neil
Do you remember the settings you use for your single Mk1 Amal? I've just adopted the same layout but would be interested to know what Main Jet, Pilot Jet and cutaway you ended up with?
Hi Pete,
I posted on another message but if your bike is a 750 that will not apply. I wrote down what I remembered but because it has run perfectly this last 5 years, I haven't needed to touch it. The way it should be.
Can't remember if the slide was 3 or 3 1/2? I know, I should have written all this down! Was the stuff I had to change I remembered because I had to pay for the bits...
I strongly recommend you drop John Dunn a line, he is very helpful and will help you best.
Thanks again I will keep with the old style plugs seems to running the best It has at the moment.
