stator wiring
just to confirm that the stator wires come out at the front of the unit not the rear where t they are perilously close to the primary chain, as a matter of interest if fitted the wrong way round will it make any difference? kind regards
'nother question, the book states a 10ah battery for the Commando, however I have a Boyer fitted, the original type, and I'm told they don't like having low power so would a 12ah or even larger be beneficial? gotta buy a new one anyway.kind regards
Fit it anyway the wires will reach. it does not matter.
It is low voltage the Boyer Ignition does not like, not low power. The ah rating of the battery will not make much difference.
As long as the charging system is working ok, then the voltage will be ok.
