Hi everyone,I'm a new member, and I'm about the purchase a 1973 Commando Interstate with matching numbers and in original condition....
The bike was originally located in Holland (i'm located in Germany), my seller, who saw the bike and bought it and imported it into Germany, and have not had it registered...Now I'm looking for paper work so I'm able to register the bike with TUV here in Germany. As TUV requires me to prove the bike is original etc. etc etc... lots of paper work and worries when buying into a truly classic bike.
Anyways, my seller sent me photos of the headstock with the Vin number, BUT, there is no MONTH & YEAR on the headstock as suggested by the NOC Factory Record Form Application...The vin is clear on all photos, engine, frame, transmission etc., all very clear it's matching... Anyone have any idea if I'm buying into a problem? Or does this happen some times where it is not printed?Thank you for any information and your opinions.
Richard.
whatsapp-image-2017-02-23-at-04-25-58-jpeg
It's not uncommon to see…
Yes , Norton VIN plate dat…
Yes , Norton VIN plate data in '73 was inconsistent. VIN plate on my '73 MK 1A 850 hasonly"9/73" stamped on it with the space fora frame number stamp left blank. This was the time of the last gasps of the old British motorcycle industry and ensuing financial chaos with BSAdisappearing from BSA-Triumphand the remains of Triumph (three cylinder Trident machines only - the twins becoming Meridan Triumph after a workers sit-in)thenmerging with Norton Villiers to form NVT in 1973.
Your apparently blank VIN is symptomatic of '73 production. Engine number should give you the production year (and approx month) with frame stamp on the steering headstock also providing some good clues.
New frame number/vin plate…
New frame number/vin plates are available from andover norton and a lot of other sources online.
Number stamps are available from any good tool shop.
I in no way condone nefarious activity, but if you legitimately own the vehicle i don't see a problem with doing what you want with your own property to expedite/mitigate a situation.
Enough said.
Hi everyone, Thanks so muc…
Hi everyone,
Thanks so much for your replies and opinions.
And apologies, the bike is a 750.
I am not yet the owner of the bike, but I have made travel plans to see it on Saturday morning with a van ready to buy IF the bike is what it is.
Last evening, I sent two records application to the NOC, Dave checked and he could only comment same as what you guys have said... Lack of records and from what little info available , my bike could be a November 1972, which still makes it a 1973, as it was registered in May 1973.
I'm a little concerned as to IF I should go ahead and buy this bike, as the seller has only the Dutch papers for it, which the German TÃV person has already said it won't be enough.
The other worry is that I'll be buying unit a Combat engine, which the seller says it isnt.
Is there a quick way of spotting a Combat engine? I've read something about numbers top of the cam?
Thanks again.
Combat should have a big C…
Combat should have a big C stamped on the top of head towards the front, it was an option linked to a front disc in 72, by 73 this link was broken.
The combat engine isn't s…
The combat engine isn't something to be feared, they were tuned to produce an addictive rush of top end power, and unfortunately this meant they were thrashed mercilessly and gained a notoriety for unreliability.
Ridden with due mechanical sympathy they are as reliable as any other commando...
If you need it they have the extra boogie to overtake porsches on the autobahn!! Probably.
Hi Richard What did you me…
Hi Richard
What did you mean exactly when you said "the plate looks to be the 850 type but the frame number stamping (which is not a factory impression) suggests a 1972 750"?
You think the headstock vin was restamped?
Previously richard_payne wrote:
It's not uncommon to see 1972 or '73 Commandos with no dates. The crisis caused by the Combat problems caused quite a build up of machines at the factory and they were not despatched in sequence. I had an early (January ?) '72 with undated plate that was not sold in the UK until the September of that year.
Is the bike a 750 or an 850 ? The plate looks to be the 850 type but the frame number stamping (which is not a factory impression) suggests a 1972 750.
I think that it would be a good idea to contact the Club dating officer to find out exactly what the bike should be and when it was despatched. Year of registration could of course be later but then the plate is probably a replacement (of course if there was no date on the original, they couldn't copy it over).
As far as I'm aware (and…
As far as I'm aware (and if you 'Google' "750 Commando frame number" you'll see quite a lot of forum threads), no 750 Commandos had frame numbers stamped directly on the headstock. My '72 certainly didn't and I have never seen any which were.
It may well be that this was a requirement in some markets and that the importers carried it out. To be honest (and I stamp quite a lot of components at work), the stamp does not look to be the work of someone with much experience. The numbers begin to go slant and go uphill. Added to this, I'm not comfortable that the curved top '3' comes from a 1970s UK punch set. It is more likely continental. I've only seen flat-topped '3's on Nortons.
Personally, I have nothing against owners replacing tatty VIN plates and it is not impossible that someone could have wanted the extra security of a stamped number. It was probably not for nothing that for a few years in the early 1970s, the Commando was the most stolen motorcycle in the UK. They were a ringer's dream.
I doubt there would be a p…
I doubt there would be a problem with the bike in the UK even though I agree with Richards opinion that the plate is new & not original and the stamping on the frame is not factory stamping but from later and to me looks very recent. However none of us UK members will know what issues you will get in Germany, would a dating cert from the UK club be enough, would the TUV object to a new looking plate and the frame and not the plate being stamped. Maybe you should ask Joe Seifert of Norton Gmbh before taking a gamble.
Understood. and thanks for…
Understood. and thanks for the explanation.Could you guys also take a look at the engine and (i'm guessing) transmission number? Both are matching, but the transmission number looks very odd to me, like it was done by a drunk worker on a sunny day, and also, on the vertical surface, there seems to be another number?Previously richard_payne wrote:
whatsapp-image-2017-02-18-at-22-22-05-jpeg
another number: Attachment…
another number:
whatsapp-image-2017-02-18-at-22-22-36-jpeg
Thanks for the tip, I'll…
Thanks for the tip, I'll email him right now.
I hope i'm not shooting i…
I hope i'm not shooting in the dark here.. Joe's website looks like it hasn't been run for some time?http://www.nortonmotors.de/
I sent him an email, fingers crossed something comes back by tomorrow evening... when I'll be on the road for 6 hours driving from the east to west to see what I Hope to be a good and legit bike.
I'll stick my neck out an…
I'll stick my neck out and say that none of these numbers look original. Someone has stamped them in these assorted places.
When I worked in an an area where bike theft was common, I stamped the registration number of my bike in various places for some semblance of traceability. Stamping frame numbers doesn't do this.
I would frankly be somewhat suspicious of this bike.
How about this number on t…
How about this number on the vin plate?
Even tho I'm reading from above that this plate could be new...
img-20170222-wa0000-jpg
It may well be that Joe Se…
It may well be that Joe Seifert at Andover Norton has some 72 assembly books but you still have to decide on the numbering aspect.
The gearbox stamping is not original. Many of us have broken gearboxes. Personally, I've never stamped a new replacement and I always reatin the damaged original with the motorcycle - No guarantee that the next keeper would though.
750 boxes had neatly stamped numbers and a letter code such as in the image below.
I think that the engine number looks OK although I have seen them look more uniform. It's certainly never been altered and they are the correct 1973 MkV 750 casing.
There are all sorts of legitimate reasons why frames, crankcases and gearbox shells could need replacing but if you're at all worried about the aspect of registering in Germany then the best advice is to leave this one alone. There will be one with better numbers along soon. Let a Belgian or someone from a similar country with no annual tests and no inspection for EU vehicles take this one on.
img_1222-3-jpg
TÃV is the second thing t…
TÃV is the second thing that's stopping me, the bike being legit will be the first...
I'm taking a friend to see it with me, his father has restored a wonderful 850mk3 and my mate knows a bit about them.
I'll still take a drive to see it, but if it's not all correct, I will be stepping back from it.
Got a reply from Joe. Whic…
Got a reply from Joe. Which was a nice surprise, as I didn't expect an email so quickly. Nice of him to give me his opinion from my side of the pond. Like everyone said, numbers are a bit iffy at best. The bike looks beautiful, maybe too beautiful for what seller says to be a "not restored bike".
Based on my discussions with my mate, information from all you nice people , and the detail email from Joe...
I'm going to leave it this time. It's too many bad feelings in the gut not to be 100% sure on the originality of the bike, especially for that kind of money.
Thanks everyone. I might have missed out on a great original deal, a nice restore, or a stollen bike... We'll never know, but I feel better I decided to sign up here and find answers from people who knows more than I do. Cheers. Hopefully you'll hear from me again and I'll have a Norton sitting in my garage.
Rich.
