Hello all
I've recently fitted one of these oil pressure sensors to my 1972 Roadster and thought I'd share the information:
It fits to the rocker feed oil supply on the timing side using a double banjo bolt. I used copper washers (2x 3/8in, 1x 5/16" ID) in preference to the Dowty seals provided as I found they fitted better. The wiring is a simple switch on the earth side and I had the indicator warning light (centre one) in the headlamp available to use.
The switch is available for $30 from Don Pender. http://www.tritonmotorcycleparts.com/297620484 although not listed yet on his website but just email him at the address shown on the website. I paid via Paypal and the switch arrived within 2 weeks. The sensor will also work with the combined Charge/Oil Pressure Warning light from http://www.improvingclassicmotorcycles.com/products.htm if you do not have a warning light spare.
It's a bit 'snug' between the engine and gearbox but fits fine:
This is a basic sensor but could help indicate a major failure of oil pressure, e.g. anti-wet sump valve failure or forgetting a manual switch. The warning light goes out after running the bike for around 5 seconds in normal use. Not standard for a Norton I know but it could help avoid a 'Not a good day' event http://www.nortonownersclub.org/noc-chat/technical4-commando-forum/759661646?b_start=0#85312273
Andy
Richard Venhill do them. T…
Richard
Venhill do them. There may be other suppliers.
http://www.ebay.co.uk/itm/Venhill-5-16-Bsf-Domed-Double-Banjo-Bolt-Chrome-/302077560589?hash=item465539c70d:g:JnYAAOSw8w1X3gTi
Andy
I've seen a similar set u…
I've seen a similar set up with a thicker aluminium rocker spindle plate tapped to take an oil pressure switch.
Previously Andrew Heathwoo…
Previously Andrew Heathwood wrote:
Hello all
Hi Andy
Did Don also provide the fitting between the switch and the banjo bolt?
Thanks, Derek
Derek Don provides everyth…
Derek
Don provides everything shown in the first photo in this posting.
I.e. i) sensor/switch - fixed to hexagon nut and banjo
ii) Double banjo bolt and two dowty seals
iii) Spade connector
Andy
Where in UK can you buy a 'double banjo bolt'?
