I'm thinking about doing some touring with my '71 fastback. Can anybody recommend panniers or other luggage carriers..
Thanks in anticipation Alan
Can't beat Craven, in my…
Fastback showing out of st…
Fastback showing out of stock but ring them and they will make you a rear carrier in stainless.
I am still using my Craven…
I am still using my Cravens and rate them. It's also a jolly good rack in it's own right, properly engineered to take the weight away from the rear frame loop via the stays leading down to the rear footrests.
Previously alan_blackhurst…
Andover Norton do Hepco & Becker stuff, not sure if it will fit fastbacks tho...
https://andover-norton.co.uk/en/shop-details/17034
regards
Gordon.
Previously gordon_robertso…
regards
Gordon.
The picture here
https://andover-norton.co.uk/en/shop-details/16988
suggests that it will (n.b. early type silencers, but I suspect the panniers would clear pea-shooters too).
The Hepco and Becker set f…
The Hepco and Becker set from Andover Norton is fantastic, if a little expensive. The panniers are large (if you choose the large ones) and do not fit parallel to the seat-stay frame tubes; they sit out quite noticeably at the front. Of course, you can't see this when you are sitting on the machine. The carrier rack is straight-forward to fit with black cap silencers and their respective brackets but very complicated with the reverse-cone silencers; the fittings are all in the way of each other. The frame is sturdy and very well-made. One additional complication is that you have to remove either the carrier frame or the shock absorbers to adjust the suspension; the lower frame stay is exactly where the adjusting spanner is designed to clip on. When I camped at the National Rally in Wales in 2015 I left the panniers at the site while touring around. I found it quite frustrating to be on the firm setting with no easy means of adjustment.
Best wishes, Colin Cheney, Leicestershire.
Thanks Colin and all the o…
Thanks Colin and all the other responders.
I'll probably go down the Andover Norton route after the TT funds permitting
Regards Alan
I'm also think of fitting Panniers
Hi, I'm also thinking of fitting panniers to my 1972 Commando in preparation of going on holiday with my wife on the back, so the question I have is do the panniers that you get from Andover impede the person on the back, in the photo they have on their web page its hard to see, I did send Andover an enquiry but they couldn't give me a definite answer, you would think if you sell a product you would know about it. Anyway, if anyone has fitted these and could tell me the answer I would really appreciate it.
Thanks for your help, Mick.
I fitted the Hepco and…
I fitted the Hepco and Becker and have found them ok, I've not tried them 2 up.
Luggage two up.
My good lady wife and I have just returned from a 2000 mile trip to the Alps and Italian Lakes (would have been longer but took motorail for part of the way back and saved 400 miles). We were on a Mk 111 Commando with ‘L’ style Craven carrier and Craven Comet panniers. The Craven kit did us proud. Bought secondhand out of Roadholder 10 years ago and repainted/replated. My wife advises that she is c 5’8’’ and would have found wider/bulkier panniers a problem when getting on and off the machine.
Can't beat Craven, in my view: https://www.cravens.org.uk/
At any rate, that's what I had back then -- can't claim experience of current production
