Hi, I have bike which I want to buy.
i need to know if it?s 1969 S.
photos attached
450908D3-EBE0-4B0E-9380-BEDEE90CA5
Is that what is called a L…
Hi, its iffered to me as N…
Hi, its iffered to me as Norton S scrambler? 1969
Previously halldorandri_ha…
photos attached
Based on the engine number of 131420 this was probably initially an S but the exhaust implies it is now a roadster. as there is little difference.
Previously Tony Ripley wro…
photos attached
Hi Tony, thanks, another nike I look at, 131481, shoukd also be the same?
best
hal
Previously paul_standeven…
Previously paul_standeven wrote:
Is that what is called a Long Range Fastback?
Tank looks more like a Hi rider tank.
The Commando S type and th…
The Commando S type and the Roadster were the same bike apart for the exhaust system, and they both shared the same owners handbook.
Right! You can use both ex…
Right! You can use both exhaust systems. Here is my 1970 Commando (blue) as a Roadster :
and as a S-Type:
Had to go as a Roadster temporarly because the left S-type header broke.Same bike only different tires and wrong seat, got the original seat later via ebay.
