Almost ready to fit the Refurbed Cylinder head and happen to recall and re-read the Chapter 29 - Oil leaks section in my Dominator Service notes V1.2 . Advising to open up the drain hole in the head gasket to fit an `O` ring or even a small hollow dowel . My question is if I fit a dowel can I make it a good fit in the original hole or do I have to bore the head and barrel and fit a bigger dowel to retain the original drain hole size ? Is it important to retain the original diameter ?
Remind me please, Wayne -…
Still doing the 88 Howard…
Still doing the 88 Howard. All standard apart from a T2219 @3 cam which I believe to be a SS . 3 start oil pump and gear.Forgive my sillyness but not sure about your question about the Scavenge return oil feed to the Rockers ? It has the usual oil pipe going to the Rockers if that`s what you mean ? The bottom end is painstakingly already assembled so dont want to lift the barrels again if possible . It might be that I should have done all this when the engine was all in bits ! How would you open up the drain hole all the way down through the barrel ? Maybe fitting the `O`ring would be the easier route but I guess that doesn`t solve all the smoke and leaking problems . If I have to I will remove the Barrels .... I`ve got all winter and I would like it right after all the work .
So, Wayne worry not. Does…
So, Wayne worry not. Does the oil pump have an S stamped into the front of the casting ? That signifies an SS oil pump, in which the scavenge gears are twice the width of the feed gears. If it doesn't have the "S" then it is more than likely a standard Dominator pump. So assuming no "S" then, in the build-state you have there will not be any over-oiling in the head so you don't need dowels, larger drain hole nor "O rings." From the image you show it does look to me that your 500 has the stronger late crankcases - there seems to be a shadow along the cases towards the join lip, just above the copper breather pipe. Is your engine a late (1961) 88 ? Whatever, you seem to be building a good motor. Good luck, Howard
That`s a relief ! I`ve…
That`s a relief ! I`ve checked the oil pump and there is no `S` on it . The bike was first Registered in April 1959 with engine number 9112153 as in the original `Buff` log book that I kept. Engine number 763531 122R is what`s in it now so an engine or cases change took place at some time. I have a new V5 with the updates thanks to the NOC. The `shadow ` may be where the inner primary chaincase has worn .The only other numbers on the cases are 88 C 271. please see attached pics. Thank you for the encouragement and advice. Not having done a Norton before I want to get it right but sometimes think I am monopolising the forums !
Hi Wayne again, I don't want…
Hi Wayne again, I don't want to be a 'party pooper' but that engine number looks like a 122 P to me. The serial number beginning with 76___ also tells me that it is earlier than 1960. The P says 1959. If your documents show that it is 1960 who am I to contradict ? C would signify that a Coil ignition set was fitted at the build stage in the factory. It looks like you're using a Manual magneto which is great. Regards once more. Howard
You are Right , my mistake,…
You are Right , my mistake, it is a `P` which does confirm it is 1959 as per the original Buff log book Howard. Ignition wise it came with a worn out Distributor which I`ve replaced with a Tri-Spark system. Thanks again . Wayne .
Hi. 59/60 was a time of…
Hi. 59/60 was a time of changes, lots of coil ignition bikes were built , lots of engines built in 1959 were fitted to the DL series and sold later as 1960 bikes ,this was normal practise, ,plenty of DL machines hung around for a year or so in dealers showrooms . They were not liked much by the "fast" guys . Guys that really rode and went places fitted panniers and Avon fairings , their passengers appreciated the panels as something to grip with the legs and kept them away from the muck.Lots of these enclosed bikes including many of the very few 650DL's made went to eastern Europe at a special price, never to be seen again . Anyone know where one is ?.Or ever seen one ?.
Always good to get history…
Always good to get history like this Robert , thanks for taking the time.
The P indicates a 1959 made…
The P indicates a 1959 made motor, the P in later engines from around 1963 indicates made in the AMC Plumstead factory . AMC did not seem concerned that they were making a mess of the Norton dating system ! . They had very little respect for what went on in the antiqated and outdated victorian Norton factory. When they tried to replicate the quality of machine that came out they filled skips with substandard parts . It took a while to catch up with those talented Bracebridge st engineers that got laid off.
Strange Numbers
The engine numbers posted by Wayne have too many digits.
If the bike was first Registered in April 1959 with engine number 9112153 then this should be just a 5 digit number.
Likewise, engine number 763531 122R should also be a 5 digit number.
All the Heavy Twin engines up to late 1961 had 5 digits. They then went to 6 digits but not as high as 763531. The last Commandos were only around 330000.
Adding to the confusion......the number on the rear of the crankcases 271 is too low for any Model 88. The first Model 88 being 122 47300 built in 1952. This has SN T7978.
The only engines that I can find with shop number 271 are a 1952 Big 4 and a 1949 Model 7.
The Model 7 SN being prefixed with a letter 'T'. ie T271.
Wow , I guess all I can do…
Wow , I guess all I can do is `Keep calm and carry on ` ! as I have no idea why the numbers dont Tally up . It doesn`t look like the case has been re -stamped . Certainly cased a stir though . Thanks everyone .
Remind me please, Wayne - are you still rebuilding the 88 ? Has it got the scavenge return oil feed to the rockers etc ? Are you using a 6-start oil pump gear or an SS oil pump ? The larger drain hole for oil from the head aims to remove the excess pools caused when different combinations of the above are used. Eventually the excess oil can flood all the galleries in the head and pour down the guides making smoke and sprouting leaks. Even a hollow dowel in the existing hole will restrict some oil passage so I usually carefully increase the diameter and provide a gentle lead-in staying away from the edges. Be careful when opening up the hole through the head gasket, base gasket and crankcase. With the scavenge feed, an SS pump and 3-start oil pump gearing you will not need to bother. Good luck, Howard
