Hi I've just been out on a very cold ride for an hour or so around town and twice it felt like it ran out of fuel, and stopped.
I fettled the fuel prime lever a couple of times assuming the car was empty and it restarted straight away.
3rd time was more scary on the dual carriageway at 60 to 70 when it died. No hard shoulder and NOONE moved to the outside lane. VERY SCARY! For a moment an arctic came by and I actually leaned in!
Anyway, primed it again and restarted.
Do these bike suffer carb icing? It's around 1 deg.
I've only had it a short while and this was probably my 4th ride on it.
I moved the reserve in and out each time in case it was that.
I've really no idea as it's recently had a good service and carb was drained, cleaned etc. No issues in warmer weather.
A shaken and cold Paul!
Hi Paul,I have had similar…
Carb icing...
... normally occurs when there's high humidity and air temperature is above freezing. So if your weather is like ours here - dry but around zero - I'd not think it was that.
How old is the petrol, as summer blends are different to winter ones as I Understand it.
I used that Silkolene product many years ago when I was running bikes all year round and felt it made a difference. But probably just wishful thinking.
Thanks will try. I used the…
Thanks will try. I used the bike probably end Nov. Had new down pipes completed yesterday so it's not been used during that time.
I went to fill up today as I thought I was running on reserve as it did it in nov but it had half a tank of fuel in it so it's possibly not just carb icing...
Some people wrap the carb…
Some people wrap the carb with old socks or similar and claim it helps prevent icing.
My Triton stopped icing the carb up when I changed from a single 389 to twin 928s. No idea why that fixed it.
Hi Michael, It is the high…
Hi Michael,
It is the high speed air going through the carbs that causes the drop in temperature. By going to twin carbs, you have halved the amount of air going through.
Submitted by Tony Ripley : …
"It is the high speed air going through the carbs that causes the drop in temperature. By going to twin carbs, you have halved the amount of air going through"
Thanks, that makes sense. Half the amount of petrol being evaporated in each carb too.
My 99DL has stopped from…
My 99DL has stopped from icing several times. It allways re-starts after a while. Its not uncommon on bikes without a carb heater , Old VW bettles could do it too. perhaps substituting an alloy spacer for the phenolic one during the winter months could prevent it. Perhaps the rear enclosure deflects the engine heat away from the carb? Possibly after starting and warming up we should wait a while to allow heat to transfer from engine to carb. An electric element wrapped round the carb body would be a good fix ,an old 12v heated bar grip ?. I have an old 12v campers Hair drier ,arrange for it to blow warm air into the Air filter !!, My bike once had some fibreglass engine enclosures also fitted ,the previous owner rode it all year all over europe ,perhaps the bike ran a lot warmer from it?. Enclosure was called "Fairshields " probably by Avon ,never seen another.
Thx. Just ordered some of…
Thx. Just ordered some of the silkolene stuff mentioned above.
Another (daft) question, can you run out of fuel if on the reserve tap all the time?
I'm not sure that I've been correctly using the fuel tap having read the manual this afternoon!
Domi 99 1961 dl died 3 times
Could it be due to a blocked tank vent hole Similar symptoms!
Laurence
Not sure. I replaced the…
Not sure. I replaced the fuel cap when I bought the bike as it was a little corroded. Maybe I'll try the original to see if the replacement is causing issues.
Running out of fuel
I have an original Ewarts single plunger tap that incorporates a reserve . The reserve holds very few miles use . It also does not seal well between main and reserve . If you have a very economical machine and ride at 40 mph it's just possible to drift along on the leakage and not realise until you are completely dry! It only works if your bike is capeable of repeating the feat that the official road test machine did, over 100 mpg! .
They all do it
My 99 was very prone to carb icing in winter. Generally just stopping the engine for 3 or 4 minutes to let the engine heat get to the carb would melt the ice and all would be well. What can happen though especially on a fast dual carriageway is that the ice build up jams the throttle open so that as you approach the end of the carriageway and see the roundabout looming the throttle won't shut.
The other effect of carb icing is that the partially blocked carb runs rich and you can get black smoke and awful petrol consumption.
Speaking from experience here.
My bike restarts straight…
My bike restarts straight away tho. Maybe I've got some other fueling issue?
I little fettle of the primer lever and she restarts.
You can measure how long it…
- You can measure how long it takes a litre to run through the carburettor.
- You can see how it goes on a warmer dry day.
The vent in the tank cap can…
The vent in the tank cap can be tested too. If it has the visible little hole in the top surface, blow through it into the tank.
Dominator 99 1961 dl died 3 times
Had a similar problem on my model 50, in good weather though. Engine would stop after 5 to 10 miles. Found the problem when I was draining the petrol tank, good flow of fuel then a dribble. Turned out both petrol tap filters were clogged with a grey paste. Replaced both taps and removed the fuel diamond which had been in the tank when I bought it.
Sounds very much like fuel…
Sounds very much like fuel starvation, easily tested next time it happens crack the fuel cap, if the bike picks then you have the answer.
Carb icing.
Funny how sometimes we live in a different world to our mates! Never had carb icing. But I have had the reverse on a Reliant.
As built (in the 70s) the carb was mounted direct to the (water) heated manifold. Fag shop syndrome, stop at fag shop, return to car, restart was very i'fy' and driving became hit and miss for a couple miles. Boiled carb.
Answer-fit a carb insulation washer. When we told the factory, they agreed they had a 'sometimes' problem but not enough to spend 30P on parts to put it right in manufacture. Not surprising the British motor industry failed.
On the pull out and turn…
On the pull out and turn round knob tap, is there a filter inside it?
I'll pull off the panels at the weekend now its getting a bit warmer and will take a look.
Best to fill petrol tank up…
Best to fill petrol tank up, disconnect pipe from carburettor and drain off a gallon of fuel to make sure there is a steady flow of petrol. If not you will need to unscrew the petrol tap to access the filter and flush out any sediment in the tank.
OK so it's inside the tap…
OK so it's inside the tap or the tank?
This is what mine looks like. Does it matter than the fuel pipe drops below the carb inlet?
Are the filters available or is it a new tap or is it washable, or shall I remove it and fit an inline filter?
Was a little wet at the tap too - assume I'd need a new tank seal too...
Tried Andover and they just said not available!
I've found that the NOC shop…
I've found that the NOC shop has a range of reasonably priced taps (that include filters) - order Sunday evening and get before the next weekend for a very low postage charge.
Could the looping round of the fuel pipe near the warm engine cause an issue?
I'd have thought the pipe…
I'd have thought the pipe should be from the top and down into the carb not up into it!
Don't let the petrol hose…
Don't let the petrol hose touch the head or barrel!
I remove petrol tap gauze and fit an inline filter. The gauze is a built-in breakdown.
Petrol Tap Filter
Hi, Paul.
To answer your query the filter is part of the tap and is inside the tank so you need to remove the tap to ensure it's clear. There is another filter (or should be) inside the union the petrol pipe connects to on top of the carb.
As mentioned, I think it would be best to route the pipe away from the hot engine. Regarding having the pipe routed so it has an upward trajectory to the carb, this doesn't matter as long as the reservoir (i.e. the tank) is above the carb.
I would suggest using a Dowty washer to seal the tap to tank since this is a little pliable so allows you to have the tap facing the way you want it to be without being over tight, as you would need with a fibre washer.
HTH.
petrol tap and filter
thanks all
I note the pipe into the union seems to be of a fixed or crimped type. Not sure whether the banjo will be this one which looks like a push on banjo 376/097 AMAL SINGLE CARBURETTOR CONCENTRIC MONOBLOC BANJO 600 900 375 376 389 | eBay
will fit a banjo union if needed although I've found an entire pipe and banjo on Andover Norton.... , new pipe - is it 1/4"?, and new washers and a new banjo union filter. If I remove the tap filter, and there is one in the banjo fitting of the carb, do I need 2?
Re the tap, I'm not sure where the leak is coming from, I think its the plunger - can the gasket be changed on this or am I dead in the water? I found a cork one on Feked actually so may be ok. Assume it's brittle cork. Maybe I can avoid a new tap.
The Tap looks to be the very…
The Tap looks to be the very rare and desirable orriginal Ewarts . the fuel pipe run is pretty much as built except you have a very usefull extra 90 degree elbow that allows an even better run than the standard arrangement for a DL that is usually pinched by the sidepanel .I shall fit an elbow just like yours. Stick with it! I have just replaced my orriginal (64 years old plastic pipe ) as it was very hard and ridgid, and i thought it may shatter sometime. It been a real bother trying to avoid it getting pinched by the sidepanel. the tap may need a new cork fitted , no bother i have found . No one except ME ! seem to have any new extended nose plungers of the correct type . But they all think they do ! Fools all. The corks are availiable but need to be a tight fit if they are to last and seal . I can detail the process if you get in trouble . Do not lose or damage the plunger retaining screw .You wont get another and they are not simple .Corks will last for years if fitted right. They get worn from the rust particles that escape the filter.Wash out the Tank. Never had vaporization trouble but had freezing carb.
Thanks Robert. I read about…
Thanks Robert.
I read about dunking the cork in hot water and using soap to slide it on. https://andover-norton.co.uk/en/shop-details-2/22231
Seems to be a suitable fuel pipe replacement.
One thing... And I know there's some quirks on the bikes. Is the thread for the tap into the tank typically clockwise doing it up? Don't need to be breaking the tank! Thx
The hot water may help for a…
The hot water may help for a while and bar soap will lube and fill imperfections in the cork. .the knob can be punched off and a new cork fitted knob re riveted . Cork needs to be bigger than the hole. be carefull to take photos before as there are two ways to assemble . some just slit cork end to end and fit.,good cork has little or no imperfections.you may have to buy corks from different sources to find ones that fit. rub round with fine sandpaper if much too big. Needs to be very tight and will bed in with use. Fit an air filter as stones get thrown forward by back wheel. No oil leaks ! very good. !!
One thing... And I know…
Don't think I've ever seen left hand threads in the fuel system.
thought it looked that way! …
Many thanks Mike and Robert
Got a 20l fuel container on the way so guess what I'll be doing at the weekend :)
I tip the tank contents out…
I tip the tank contents out over an old kitchen bowl and with tank still upside down wipe inside the filler cap area with kitchen roll to get the grit .after standing the fuel goes back in as water and grit settle in the bottom . Note ! I did say OLD kitchen bowl !!
Nothing to do with carb icing......
Nothing to do with carb icing, if it was you would feel a very slack throttle as the cable no longer pulled the slide when it happened.
Petrol pipe 'through' the manifold is causing petrol vaporising it appears to run out! by the time you slow it will probable clear but it has to refill the float chamber, so takes a moment or two. Ie you stop and park up-all is now well.
You can have carb icing…
You can have carb icing without a stuck throttle slide.
Hi Alan, I'm going to…
Hi Alan, I'm going to reroute it so that should also prevent this.
I agree Michael, suffered…
I agree Michael, suffered icing on a number of occasions ,no slide issues at all . frost forms around the air bleeds on the needle jet stopping the flow of fuel.
Well I didn't get far -…
Well I didn't get far - after emptying the fuel tank (and having a banging headache the following day), the fuel pipe provided by Andover Norton doesn't fit (I've fed this back to them). The nut under the tap doesn't do up very far, so thats wrong, and the pipe wouldn't fit as it was impeding the side fairing and the tickler lever. Part no NM22265 is no good for the DL!
Also the gauze filter soldered on the tap inlet had a hole in it so I've ordered some mesh to replace that. Hoping I can add a dab of solder to hold it.
And some new E10 proof hose which I'll still have to run around the carb but away from the cylinder.
Tank looks good inside - its clearly been refinished.
Hose required 1/4" bore. The…
Hose required 1/4" bore. The setup you had was good . Use acid plumbers flux , you can get new filter tube but soldering it can be frustrating don't change things unless absolutely needed . Old stuff is good ,new stuff not always!
Thanks. Ordered some brass…
Thanks. Ordered some brass filter mess from ebay and was easy to replace it. Ignored my soldering!
New hose. Had to adjust the…
New hose. Had to adjust the body panel brackets as the tank was rubbing on the paint. But after the 2nd refill and drain it went back together and no leaks.
Carb Union
Hi Paul.
Your image of the carb shows a fibre washer under the carb union. I know that not all models should have this and many rely on the filter as a seal though am not sure if this is the case for yours. Perhaps someone could comment with the definitive position. If it shouldn't be there, when fitted it has the effect of raising the fuel level so could result in an over rich mixture. Something to at least bear in mind.
You mean the red gasket…
You mean the red gasket under the nut? Didn't touch that. Where the banjo fitting slides over the filter, the nut under it?
Carb Union
Yes, Paul.
My guess is that the carb on your bike is probably original to the machine and probably should not have the red fibre washer. You may prefer to see how it runs eventually and then decide if it needs removing if you're having over rich symptoms. A pretty quick adjustment to make.
That's obviously....
... not a new carb therefore shouldn't have the fibre washer under the float needle housing.
Hi Paul,
I have had similar. But mine was the carb actually jamming open. Turned the ignition off, felt the carb and it was icy cold, held a warm hand on it for a while then heard the slide clunk back down.
So, yes, they can suffer from icing. Does not really help as I do not have a solution.
Do you have a large insulating washer between the head and the carb?
Hopefully someone else will come up with an actual solution.
Update, A bit of research has come up with:-
Silkolene Pro FST
Multi-functional fuel treatment. Protects against cold start wear, corrosion, carburettor icing, deposit build up problems, stalling and rough running at low engine revs.
No idea if it is snake oil ...
