Mk3 Commando Steering Lock Removal and Paint
Almost the last job before finally being able to start the build up of what was a sad, butchered Mk3 wreck (approx. 60% had to be replaced or was incorrect/not present) is to refurbish the fork yokes.
The steering lock had no key and was heavily corroded, so needed replacement.  I bought a long 1/8" Bosch HSS drill bit, thinking I would drill out the roll pin.  Using slowish speed and lubricant did nothing except make the roll pin shiny!  Giving up that approach, I decided brutal was the next best option.  Using a large punch and hammer, two blows pushed the tumbler down to the locked position, and two more blows saw the lock assembly drop out after shearing the roll pin - why did I waste money on the long drill bit.........?
Now the yokes are cleaned up and ready for paint, but what paint to use?  Both Norman White and a colleague at work recommended silver Smoothrite.  Norman's own bike certainly looked okay with that.  However, having bought some and tried it on a test piece, not only is it really thin and runny, it also dries to a matt finish - Norman's yokes were only shiny-ish, but definitely not matt.  I know the original Norton applied finish was not really gloss, but was also not matt, which could get grubby pretty quickly and just looks wrong too.  I have read a few reviews of Smmothrite that comment about a formulation change, so maybe Norman's (painted a few years ago) was actually a different paint?
I'm sure this question has been asked before, but website searches did not come up with anything, so does anyone have a spray paint recommendation,  ideally aerosol/   I do not want to powder coat the yokes, even though that would likely be more durable.
Regards, Andy
As you have the paint then apply several coats to get the desired thickness and top it off with a gloss clearcoat to get the desired finish.
