Hi, question. I have a clock which had an extension from the rear which looks like a net curtain wire and was broken. I unscrewed it thinking I could remove the back of the clock but have a problem. If you look at the pic where the screwdriver is. It has a stubby metal part with a hole, which cant been seen in pic. Does this unscrew? and in which direction? I cant get the clock back off because this is to thick. Any ideas guys? Thanks. Need to clean and oil trip as it is getting stuck.
Attachments dsc_0001-jpgIt'a a push fit and held…
Previously Gordon Johnston…
Previously Gordon Johnston wrote:
It'a a push fit and held in place with a tiny split pin or locking wire. It could be that a bit of the split pin is still inside the hole and stopping it coming out. If it looks ok and clear, use a bit of heat and oil andgently lever it off.
Not really electrical but what the heck.
Thank you Gordon and yes y…
Thank you Gordon and yes your right I did post it wrong section sorry. Will give that a try tomorrow.
Thank you Gordon. All fixe…
Thank you Gordon. All fixed now. The trip cog was bent and fell off when I got the extension off, it was rusted on like you said. Bit of filing and straightening and fixed it back on. Thank you
Attachments dsc_0014-jpg- Log in to post comments
